Price for New FLM Rustler?
padrino
hmmm...
Price for New FLM Rustler? - 02.08.2009, 02:30 AM
Just put together an ad for ebay or another site, curious to see what others think the market might bear for a new FLM Rustler with Mamba Max 5700 & Parts.
Ad and pictures below
I recently sold my son's Rustler VXL and now it's time to sell mine. I initially starting building it last fall as my ultimate aluminum speed machine so I focused on top of the line aftermarket parts throughout the truck. I thought I would run it this spring but now that I have it together some things have changed and I don't think I will find much time to use it.
This Rustler is new, I only did one trip around my drive way today to verify everything is working and to adjust camber and toe-in. The only stock parts are the hardened VXL transmission and front bulkhead.
Rustler Parts breakdown:
Mamba Max 5700
FLM Aluminum Extended Rustler Chassis
FLM Aluminum Extended A-arms
FLM Aluminum Upper Chassis
FLM Aluminum Steering Bell Crank & Drag Link
FLM Extended CVD Kit
FLM Aluminum 17mm Hub Adapters w/ 17mm 1/8 Buggy Tires
NOTE: All FLM parts have lifetime warranty
TRX Aluminum Turnbuckes and Camber Links all around
TRX Aluminum Castor Blocks
TRX Aluminum Steering Blocks
STRC Aluminum Rear Bearing Carriers
STRC Aluminum Front Shock Tower
Golden Horizon Aluminum Rear Shock Tower
Integy MSR9 Shocks
Traxxas 2070 Servo
RPM Front Bumper
Traxxas Wheelie Bar with Traxxas Aluminum Wheels
The following parts are also included:
NEW - FLM Wheelie Bar Mount
NEW - STRC Rear Bearing Carriers
NEW - Kimbro Heavy Duty Servo Saver
NEW - RPM Front Bumper
NEW - Traxxas 76, 90 Tooth Spur
NEW - Traxxas 31 Tooth Pinion
NEW - Traxxas Hardened Steel Idler Gear
NEW - Traxxas Battery Hold Down
NEW - 540 motor Heatsink
NEW - Extra set 17mm 1/8 Buggy Wheels
NEW - Traxxas Steering Block Pins
Aluminum front bulkhead
Lunsford Titaninum Turnbuckles - A couple may need to be replaced under Lunsford's lifetim warranty.
Extra Integy Springs & MSR9 parts
Extra FLM Chassis parts
Many Traxxas pins, clips, spacers, screws, and tools.
02.08.2009, 09:53 AM
I think you might get 400-450 depending on how lucky you get.
It is a niche buy...
padrino
hmmm...
02.08.2009, 10:45 AM
Thanks, I'm not trying to kid myself so I was hoping for $400 or more. I guess we'll see what happens.
