Solar charger
PedeBasher
PedeBasher's Avatar
Solar charger - 02.12.2009, 05:37 PM
Does anyone have any experience with solar panels?
While sitting in math today (horribly boring), I was looking at my calculator. I saw the solar panel it has on it and it only has 6 screws in the back. That got me thinking. It cant be too hard to extract the panel now could it?
Well anyway, I want to start small. Maybe with my Micro-T charger and 6 or so panels rigged into it. If that works I will go bigger into something maybe for my 606i.
Does anyone think this is possible? I know if I dont have a lot of panels I probably wont get a lot of amps but I wont worry about that now. I just want to know if it is do-able.
Some may think its stupid but for those of us that dont have cars to use to plug our chargers into, its brilliant. Cheap, easy, and ultimately light weight.
I could be a new revolution of R/C gear...
Did you know?
  Send a message via AIM to PedeBasher
pedeboi364
02.12.2009, 05:52 PM
damn wouldn't that be great. No more buying heavy, annoying, expensive power supplies!!! Call me ur official helper-tester-outer!!
Check out my FS thread in the General Discussion!! Help me go lipoly!!!
PedeBasher
PedeBasher's Avatar
02.12.2009, 05:59 PM
Thats exactly what I am thinking. If I get one working I think it would be a huge innovation.
Im sure I can get old solar panels by asking neighbors/looking around Craigslist for used calcs and solar malibu lights.
If anyone has some good info on solar panels, please post it or PM me about it.
Did you know?
kostaktinos_mt
02.12.2009, 06:01 PM
not a cheap solution...
example:
http://www.allelectronics.com/make-a...R-PANEL/1.html
you will need a minimum of two of these [~2.3amps /17v total -in full direct sunlight] for a small charger, able to charge a 2s lipo at around 4amps...
thus, the cost will be around 400$ [not including any regulating array that might be involved]...
  Send a message via MSN to kostaktinos_mt
PedeBasher
PedeBasher's Avatar
02.12.2009, 06:06 PM
Hmm... Think if I rounded up like 100 malibu panels (bought 2" by 2" if you dont know what im talking about) it could be done?
But for now, like I said, I just want to get my feet wet with a Micro-T charger.
Did you know?
Dagger Thrasher
I have no idea what's going on
Dagger Thrasher's Avatar
02.12.2009, 06:14 PM
While it's a nice idea, it's not going to happen for a charger of any real size; solar cells just aren't anywhere near efficient enough yet, so you'd need a MASSIVE array set up to power a normal charger from. For that kind of output, you'd probably be better off setting up a Pb battery solar charging system which charges throughout the day and then powers the charger from the battery; much more reliable. Even then, you'd still need a massive array.
As for your Micro-T charger though...that *might* be do-able. If I remember rightly, the Losi LiPo charger's max output is 150mA, though it has a standard AC 120V input, being a wall charger. You'd need to disassemble it and remove the transformer, which I'd imagine steps-down to around 12V. You could then just hitch up a suitable solar voltage regulator to keep the input steady under varying sunlight, and then setup an appropriate cell array which are capable of outputting at least 250mA total, at a guess (you want to be able to charge when it's cloudy!). You'd want cells of a higher maximum voltage than 12V as that'd allow headroom for when the sunlight fades; around 18V I guess would be ideal. You can mess around with the wiring config, so series-up cells of lower voltages, etc. Or use one, large 12V panel; they usually stay at a fairly constant 12V with variable current output. The voltage reg would probably have a built-in cutoff for when voltage dips too far below 12V.
That's all just a very rough plan and you'd have to look into what actual cells you can find, but it is viable...if a bit of a hassle lol.
bruce750i
bruce750i's Avatar
02.12.2009, 06:18 PM
Here are few that are a little bigger than whats on your Texas Instrument. http://search.harborfreight.com/cpis...rd=solar+panel
PedeBasher
PedeBasher's Avatar
02.12.2009, 06:25 PM
Hmm... It was a thought. I wanted your guys opinion. I think I will still pursue the Micro-T idea. If I have to, I will step down even further to a MCX charger and try that, just to say I did it.
Did you know?
