sikeston34m
sikeston34m's Avatar
03.06.2009, 01:01 AM
Originally Posted by MetalMan View Post
Where is Patrick when you need him?
But to be fair, Metallover would need one too
Yeppers, after all, Metallover was the one that sent the spark that got this fire going again.
Metallover
RC-Monster Spudgunner
Metallover's Avatar
03.06.2009, 11:24 AM
That's too true. I'm the most deserving person on this forum.
But really... I am.
03.06.2009, 11:38 AM
But really... I am.
And the most modest too. Wow you are definately a catch!
(the preceeding was complete sarcasm, no aminals were harmed in the making of this sarcasm)
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
03.06.2009, 08:14 PM
Closed-captioning provided by:
Metallover
Metallover's Avatar
I'm working on the Modest-ness. Off the forums I have started to show people my projects. I actually drove my crt in front of my dad the other day! I even revved my bad ass 318 for the first time!
SunnyHouTX
SunnyHouTX's Avatar
03.19.2009, 03:31 AM
The max RPM will greatly depend on the diameter of the motor. However, many 800kv motors won't be able to cope with more than probably 6s.
So if I remove the center diff of my truggy and replace it with the 770Kv Castle outrunner, it should be OK, correct? Max RPM with a fully charged 6S is about 19,400. Run times should be much longer than what I get with my Medusa 36-70-2000?
Thanks for your input.
MetalMan
MetalMan's Avatar
03.19.2009, 03:43 AM
Can't comment on the max. RPM of the Castle outrunners, but as a guess I would say that RPM is too much.
Also, assuming a truggy diff ratio, your theoretical top speed is past 60mph which is IMO too much stress to put on a reasonably sized outrunner.
A kv of up to 550 will net a top speed of about 45mph, which is the highest I think you should shoot for (again, my opinion). Outrunners don't make the same power inrunners do.
SunnyHouTX
SunnyHouTX's Avatar
03.19.2009, 04:05 AM
You are correct, with a CC 770Kv outrunner, the theoretical top speed will be about 66mph without any losses factored in. At 30% loss, top speed will be about 45mph. Of course I can set throttle EPA lower if it gets to be too uncontrollable. To me that point where I lose control comes in at around 60mph for a 1/8 scale. I am worried more about overheating and demagging the motor. I really don't want that to happen.
Now, when you say that outrunners don't make the same power as inrunners, does it mean that the motor will tend to overheat piddling around in my truggy? Or will the outrunner generate enough torque for a lower amp value (lower power) to move the truck satisfactorily?
Thanks MetalMan.
brushlessboy16
brushlessboy16's Avatar
03.19.2009, 06:51 AM
770 is definately way to high of a kv, i ran a Buggy with a 550kv motor and it was always smoking hot after a run.. but yeah they are torque monsters.
DLS II
03.19.2009, 09:32 AM
You mean like this?
ID:	6627   Click image for larger version
ID:	6628   Click image for larger version
SunnyHouTX
SunnyHouTX's Avatar
03.19.2009, 10:56 AM
Yes, EXACTLY like that. That looks great DLS II. What Kv is that then? Where can I get one? And what true speeds are you getting out of it? And how long of a run time?
rotary rocket
No Pistons
rotary rocket's Avatar
03.19.2009, 11:24 AM
DLS, how did you mount that motor? I love your setup.
Close up shots of the motor mount would be great.
MetalMan
MetalMan's Avatar
03.19.2009, 01:37 PM
Thanks MetalMan.
This is a hard comparison to make, considering the use of outrunners in cars is still relatively new and untested. However, for the same weight as an inrunner, outrunners generally are rated for less power. They do produce a lot of torque, as noted above, but I can't make a direct comparison to inrunners.
Just remember that your truck will require a certain level of power to move/accelerate, which won't necessarily be dependent on the motor.
DLS II
03.19.2009, 02:08 PM
The motor is 600kv. It weighs 7.75 lbs. I've yet to test it. It should do 40-45 mph and run (I hope) 15 min. The mount was made by Monster Mike. I tried getting some shots of the mount, but they didn't come out so well. It's set up 6s A123. The outrunner is a Rimfire 42-60-600. The car is a Kyosho MP-6. I call it an EMP-6. The motor mount is secured to the stationary end of the motor with 4 screws. It bolts down to the front 2 mount holes of the center diff. It is secured by the top brace that runs from the top of the mount to the steering assembly brace. It came out very well. Mike's work-mount,brace,rear dog bone and design are superb! Don
SunnyHouTX
SunnyHouTX's Avatar
03.19.2009, 02:45 PM
Thanks for the info DLSII and MetalMan. Looks like I will have to keep running inrunners for the time being.
