My Blizzard Smoked my Sidewinder
Desmo
My Blizzard Smoked my Sidewinder - 03.07.2009, 10:34 PM
blizzard, sidewinder, lrp 4300kv motor, 3s lipo. Temps after the first run where esc =124deg f motor 110f and battery 75f. Everything was going good untill is slowed down and stopped. When i picked it up it must have been 3 times its own weight with all the snow packed in it. The snow is more like ice than snow right now.
It also had the freshly burnt smell of electronics. I think I'll use my MM and a better motor in it next. What is everyone else using for esc's in blizzards?
Metallover
RC-Monster Spudgunner
Metallover's Avatar
03.07.2009, 11:24 PM
If you get your esc warrentied you might want to disable the bec on your new one if you don't already. You can also add a cap and/or a fan.
I am almost lead to beleive there was a bad solder joint.
Desmo
03.08.2009, 12:52 AM
I haven't been following the sidewinders since they came out. Has the BEC been a problem?
Metallover
Metallover's Avatar
03.08.2009, 12:57 AM
The BEC has not problem. It's just that disabling it takes strain off the esc. You can safely run 4s with the bec disabled. Just remove the red wire and add an external bec or rx pack.
Desmo
03.08.2009, 01:11 AM
It still connects to the computer with the USB. I'll try it with a ubec and see if it works.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
03.08.2009, 02:15 AM
IMO, that setup is a bit too fast for a tracked vehicle anyways. Your looking at 50K RPM at WOT. That's going to put a strain on the ESC even without 5# of snow on it.
Desmo
03.08.2009, 11:09 AM
Blah, its still to slow
What's_nitro?
03.08.2009, 07:15 PM
Hahaha, yeah you're right! I think the MM will help though. Just be careful you don't blow out the transmission.
bensf
03.08.2009, 11:55 PM
Remember that the snow isn't just weighing it down, its preventing airflow and making everything heat up more. thats how I fried my hacker motor.
