BitHed
03.12.2009, 08:59 PM
...good to know...
...personally I wish they would use bigger exit wires...those things are TINY compared to all the rest of the 10 and 12 gauge we are used to...
03.12.2009, 10:55 PM
I too have always thought the wires were a bit small, but they seem to work very well regardless.
BitHed
03.12.2009, 10:59 PM
...agreed...but it would be nice if everything was the same 'fatness' :D
03.13.2009, 10:40 PM
Im sure theres a rude joke in there somewhere, but Im too tired to even bother right now....
DARKWAV
03.13.2009, 10:49 PM
wanted a 36-50 or 36-60 Medusa motor where the wires exit the case like the 36-80 series does, as opposed to coming out the back. So, I emailed Medusa to see if a special motor could be made and this is what they sent:
Sure enough my RC-Monster order just came in and the version motor I got was the new MR-36-60-2200V2SE-5.
Side exit wires, plus the shaft extends out past the rear endbell a few mm. This motor came with the flatspot from the end all the way to the bearing...on both end so the shaft. I don't know if the flat always comes that way from Medusa or if that is just RC-M spec.
MetalMan
MetalMan's Avatar
03.13.2009, 11:04 PM
The way the shaft is on that motor and the direction the wires exit is the same as on the 70mm and 80mm motors. They probably decided it would be a better choice all-around to have all their motors this way.
