doo540
03.14.2009, 07:36 PM
Need to clarify, tires are in stock savage XL position on standard proline 40 series rims.
21.25 wheelbase, body has .25 inch clearance of the rear wheels when at full suspension travel up. Steering servo will be turned sideways to allow lipo placement in either front or behind tranny. So you can run 6s up front and 6s in rear at the same time if needed. lol Tranny will be FLUX until it explodes. Truck will also sport all 6 of the stock baja 5T body mounting hardware and full roll cage following the body profile with a .125 inch clearance.
Byte
03.15.2009, 05:24 AM
Is that 1/5 scale? My LST is only 6mm shorter than that ugly thing?
doo540
03.15.2009, 09:16 AM
21.25 is the WHEELBASE. Do you know what that means? I'm guessing not. An e-revo will fit between the front and rear tires. Not sure why you think its ugly, have you seen the sale figures on the HPI BAJA 5T? Its the same thing (on the outside). No offense but didn't they stop making the LST, and LST2.
03.15.2009, 11:33 AM
I think he confused the wheelbase with overall length... Spy pics look good Tim, I wonder if "he" would whip up a shot looking down on the truck with the stock savage x track width. The xl is wider so the tires would not stick out as far with the savage x setup.
Looking good, I cannot wait to see the proto tvps...
