03.29.2009, 11:08 PM
Originally Posted by big greg
about 44 mph on 4s with a 1515 1y. you might wanna go with a 12 running the 2000 on 4s, for 6s i would gear it for the same speed and turn the epa down, its easier to switch voltages that way
hi, did u change ur gears in your front n rear diff to x2 type? Mike said need to change
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
03.30.2009, 02:08 AM
no i do not have the spiral cut gears, that just changes your ratio, you dont acually need to, just use the speed calc. youll be fine
03.30.2009, 02:24 AM
I was told by my jamning agent that if I dun change the gear it won't be optimum.
Now my CRT is on 62spur with 14t, so if I change will be 50spur 11t pinion wo changing the F n R diff. U think better then my present setting?
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
03.30.2009, 05:47 AM
you were told that because they want your money  i originally had a 13t with the 62t spur and i hated how big and noisey it was so i switched to a 46t kyosho plastic and love it, put a 10t on there at first but the motor hit the center brace, then put the 11t and it fits just fine. my buddy runs the same gearing on his crt with the spiral cut gears, it seems no different to me, i dunno the ratio that the spiral cut are, but they are not a necessity imo
03.30.2009, 06:29 AM
Lol I used a excel sheet n calculated that using x1 CRT gear 43/13 is faster than x2 CRT 45/10 using 46spur n 16 pinion y?
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
03.30.2009, 06:52 AM
03.30.2009, 08:39 AM
Originally Posted by brushlessboy16
I m using that:)
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
Site Owner
03.30.2009, 09:26 AM
Changing the front/rear ring and pinion gears isn't an absolute necessity - as long as you have matched your motor, battery, gearing, etc. to the gears you have, you will be fine.
Even though it isn't NECESSARY, I think it is a good idea to use the truggy ratio diffs(if it was my truck, I would use the truggy diffs). The spiral gears are stronger, quieter and smoother, for one. For another, they allow a much smaller spur while retaining a larger pinion, which will be smoother again as well as last longer.
03.30.2009, 09:39 AM
U mean x1 CRT is not using truggy diff for front n rear isn't it 43/13? Or u meant 45/10 is better?
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
Site Owner
03.30.2009, 10:01 AM
X1CRT has 13/43 ring and pinion gears in the front and rear diffs - same as most buggies. The x2 and most other truggies use a spiral gear set that has more reduction - this allows use of a smaller spur in the center to achieve the same or similar overall reduction (which is preferred IMO). :)
03.30.2009, 10:59 AM
mike, this will fit the losi 8ight B right?
Originally Posted by Semi Pro
Originally Posted by BrianG
Site Owner
03.30.2009, 11:09 AM
It should drop right into the Losi buggy and truggy - minor clearancing may be needed to allow space for the slipper, though - the plastic top brace will likely need minor dremel work. :)
03.30.2009, 11:36 AM
Mike, will this slipperential works in a heavy truck like Savage? I have sent you a PM about this and would be waiting a reply from you.
Site Owner
03.30.2009, 11:46 AM
Check your PM's, Mr. O. :)
A Savage will require a pretty tight slipper setting, but it should work fine - of course a way to mount a center diff into a Savage is another story. :)
03.30.2009, 12:16 PM
Thanks Mike for the rapid response. Glad to hear that it will work in a heavy truck like Savage. Is there any plan to produce this center diff mount, http://www.rc-monster.com/forum/showthread.php?t=10233 ? I know this is for the emaxx but I bet it would not be hard to use this on a Savage with a center skid plate. I can see that alot of people are interested in this mount as well..
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
