LIpo's in a clodbuster
Savage03
LIpo's in a clodbuster - 12.14.2005, 04:00 AM
I need some quick help here, I'm building a clod for bashing with a Thundertech frame, it has 2 17t double motors (brushed) and I want to run a lipo but Im not sure what to run. Ive been told that if I use a brushed motor to use a 7.4v pack, brushless use 11.1v. Suggestions? Thanks!
nbcaznmaster
RC-Monster Cult Member
nbcaznmaster's Avatar
12.14.2005, 07:42 AM
not true. The voltage depends on ESC, and how fast u want the item. it also depends upon the motor too a lil bit.
~~~~~~~~RC Garage~~~~~~~~
LSP-R - Picco .26
Custom E-Revo - Warrior 9920/Feigao 9L
Nitro Revo - .18tm
  Send a message via AIM to nbcaznmaster
MetalMan
MetalMan's Avatar
12.14.2005, 09:52 AM
You wouldn't want to use any higher than 7.4v, otherwise you will be doing constant motor maintenance!
Sneeck
RC-Monster Custom
Sneeck's Avatar
12.14.2005, 12:21 PM
Throw a set of titan's or permax 600's in that puppy, allong with 2 4s2p pack's in parralel. That's 14,8 volt's.
  Send a message via MSN to Sneeck
nbcaznmaster
12.14.2005, 02:25 PM
cool, i dont thinkg the extra .4v would screw it up. i dont know if titats would be a good rock crawling motor....
LSP-R - Picco .26
Nitro Revo - .18tm
Savage03
12.15.2005, 03:34 AM
Thanks guys! Im not building a crawler, just a basher but I dont want a straight line speed freak just something mild fast. I was wondering about the amperage to, 12c or 20c or?
MetalMan
MetalMan's Avatar
12.15.2005, 09:52 AM
The discharge rate ("C") depends on the capacity of the pack. What are you looking at?
Sneeck
RC-Monster Custom
Sneeck's Avatar
12.15.2005, 12:26 PM
Trust me that titan set-up on 14,8 volt's is giving you the same speed's as a stock emaxx. My friend has one on 14 cell's I think and it is sick fast. Pretty uncontrolable too.
Savage03
12.15.2005, 05:45 PM
Oh thought that was the amperage or something, does the discharge rate make any diff? Would think 2 motors would draw alot so dont wanna have a flaming clod rolling down the track!
squeeforever
squeeforever's Avatar
12.15.2005, 07:03 PM
what kind of esc? are you running like a evx or 2 independant systems?
Savage03
12.15.2005, 10:49 PM
Evx.....
squeeforever
12.15.2005, 10:59 PM
i would go with something around 60 amps continuous.
MetalMan
MetalMan's Avatar
12.15.2005, 11:15 PM
You wouldn't need that much. 40amps cont. should be enough for a Clodbuster that won't be breaking any speed records.
