glitching with mmm
twisted8
glitching with mmm - 04.26.2009, 07:37 PM
im having problems with glitching with my mmm v3,2200 kv combo.im running it on 4s 5000 40c packs in an emaxx.
it happens about 50-100 ft away from me. ive tried two radios and still have the same issue. iam wondering if i need to run a external battery for the receiver or maybe run a glitch buster ?
im running a single servo set up and a personal transponder also. maybe iam taxing the stock bec ?
any suggestions ?
thanks
mkrusedc
NeuMaxx
mkrusedc's Avatar
04.26.2009, 08:21 PM
Were the radios 2.4 Ghz? The Futaba 3PM fasst fixed the glitching for me. Have you changed the antenna length? This can be a problem also.
04.26.2009, 08:44 PM
How close is your rx to your esc? If it is close, move it as far away as possible. Are all your wires braided? Try braiding your wires...even the motor, and see if that helps. As stated above, possibly move your antenna wire. I run a FM set up and after 150', it gets a bit dicey. 2.4 is the way to go w/no probs.
twisted8
04.26.2009, 10:46 PM
my receiver is in the front of the truck and esc is in the back. its a jr fm r200 radio.this also happened with another radio.
Pdelcast
Pdelcast's Avatar
04.28.2009, 06:15 PM
Only thing I see is that your antenna wire runs down through the servo hole, and then back up to the antenna. Try running it directly out the side to the antenna -- this should give you a lot better reception.
Patrick del Castillo
President, Principle Engineer
04.28.2009, 06:22 PM
I don't know the frequency/modulation of the transponder. Could the proximity of the transponder be the culprit? It is a transmitter and the antenna is awfully close...
twisted8
04.29.2009, 12:02 AM
i moved the receiver to the front shock tower and braided the wires from the motor and added a ferrite ring and no glitches.
Sammus
Sammus's Avatar
04.29.2009, 03:14 AM
htfu and get fasst :)
mkrusedc
NeuMaxx
mkrusedc's Avatar
04.29.2009, 05:45 PM
Glad to hear the problem is fixed.
twisted8
04.29.2009, 11:40 PM
im gonna race tomorrow so we will find out for sure.
