Aceldama
Aceldama's Avatar
05.09.2009, 03:35 AM
I caved and put the RCM mount in the designed location, and ditched the original carbon fiber servo plate.
I created another ESC plate that uses the original motor mount chassis holes and now I just need to create a brake servo mount.
I tried making my own motor mount out of 1/8 aluminum stock but gave up. It seems so strong at first but it ended up being pretty flimsy once I had it mounted up.
I'll update with pics tomorrow. It's about 4AM here and I'm dead.
OH, and I also drilled out the RCM brake spacer so that two of the holes would accept 4mm counter sunk screws. I needed to do this so that I could use the RCM mount with my Tekin motor that has the funky 3mm mounting hole spacing.
tedo
Vermont, USA
tedo's Avatar
05.09.2009, 07:35 PM
My RCM Mugen motor mount fit perfectly with my Tekin. I wonder why yours is weird. Now if USPS would just deliver my long shank pinion....
Good luck, nice build so far.
MBX6T: RX8 2000—sick!!!!
Campbell Buggy Rock Racer on 3S
4x4 Pede
1987 (Gen 1) Lunchbox
tedo
Vermont, USA
tedo's Avatar
05.09.2009, 07:43 PM
Hey, you can flip the mount around and mount the motor on the front left portion of the chassis.
Yes, he can flip it around, that's how I did mine. However he will have to flip the CF plate over that holds the front chassis brace, because the motor will hit the brace and you won't get a good mesh. It's an easy fix, just requires a new mounting hole on the chassis.
Oh, with the motor up front, a long shank pinion is also needed... I found this out after my build was practically done.
4x4 Pede
Aceldama
Aceldama's Avatar
05.09.2009, 08:12 PM
Well, it's finally done. (Aside from the new body I'm working on)
This morning I made a few mods so I could mount the original servo plate on the opposite side in order to maintain the mechanical brakes.
Here's the finished product:
I've given it a little romp around the neighborhood and I love it. The low speed control on this Tekin ESC is impressive. I can only compare it to my 1/10 and 1/18 non-sensored stuff but it's way ahead of those in terms of 'feel'.
As far as the motor spacing goes it seems to be a manufacturing defect on the 3mm spacing. Tekin haven't answered my e-mail or posted in the thread I've created about the issue. I only know of one other user who has seen this issue, Jhautz. It's not a problem for me anymore since I just bored out the brake spacer for 4mm screws.
05.09.2009, 08:20 PM
Looks very nice!
brushlessboy16
brushlessboy16's Avatar
05.09.2009, 08:47 PM
Very nice setup, any chance Of Video?
I would be afraid to put my lipos out in the open like that :)
Aceldama
Aceldama's Avatar
05.09.2009, 10:01 PM
I'll see if I can get some video. I just have my point and shoot camera so it will most likely be awful.
As far as the battery protection goes, that is a concern but I think it's going to be all right:
-The Neu Energy back are built like Rhino packs and have that protective skin below the shrink level.
-The strap covers most of the battery.
-The body covers the battery.
I'll keep an eye on them and if I see any marks from rocks and sand on them I'll probably add a thin sheet of plastic between the strap and the battery.
Now I need to start painting a new body.
Always Dreamin
05.09.2009, 10:14 PM
Sweet. very clean, and well put together.
nitrostarter
nitrostarter's Avatar
05.10.2009, 11:03 AM
Why not just use motor brakes for bashing? No real need for brake bias...
Looks good tho! Clean conversion! I would lay those packs down tho, on not expose them to the outside like that. Maybe have a tray that you can slide the batteries in from the top...
N. Rustler conversion
Aceldama
Aceldama's Avatar
05.10.2009, 11:39 AM
I have the misguided belief that using the mechanical brakes will prolong the life of my electronics.
I'll have to take a picture of the batteries when they're inside the trays. They're pretty far from exposed when the straps and body are on. The lip from the rock guard covers a bit, the strap and body covers the rest.
Unsullied_Spy
Unsullied_Spy's Avatar
05.10.2009, 12:06 PM
Looks very good. I like what you did with the wires for the ESC and motor, it looks very clean with the shrinkwrap slid down over the solder posts.
Aceldama
Aceldama's Avatar
05.10.2009, 01:56 PM
Thanks. I was debating whether or not to put bullets on the wires but glad I did with all the shifting around I've done. I used the Metcal MX500 we have at work to do the soldering, it was a breeze with that system.
Aceldama
Aceldama's Avatar
05.10.2009, 05:36 PM
I finished the body this morning so I took some pictures:
First is the battery in the tray:
Here's the body... I like to keep it simple:
05.10.2009, 05:37 PM
She's a beauty man.
05.10.2009, 08:04 PM
Very nice. On my e-maxx single motor mount, the screws don't line up as well. I just opened up the holes a bit
