Wire 2 BEC outputs in parallel ?
KaztheMinotaur
KaztheMinotaur's Avatar
Wire 2 BEC outputs in parallel ? - 05.17.2009, 08:09 AM
Does anyone see a problem with wiring the output of 2 BECs in parallel to double amperage?
brushlessboy16
brushlessboy16's Avatar
05.17.2009, 09:19 AM
No problem, just make sure they are rated the same.
05.17.2009, 10:56 AM
You will get more than what one would put oiut, but it won't double. You'll get somewhere around 75-80% more. The reason for this is due to how the feedback works in the switching regulator.
05.17.2009, 11:23 AM
stand alone bec- sure
esc's built in bec- I thought this was bad.....
Brian?
05.17.2009, 11:28 AM
Yeah, I personally wouldn't parallel BECs at all. It depends on the design of the BEC circuit really. I've had a BEC (can't remember which) get really hot if the output was fed with even a slightly higher voltage.
If you have a high servo load, I would just run a seperate BEC on just that device. It's just a matter of isolating the red wire, but the ground and signal wires need to be directly paralleled.
05.17.2009, 11:33 AM
thanks
KaztheMinotaur
05.17.2009, 04:14 PM
Thanks.
Any thoughts on how much current an AR6200 RX or a heli gyro would draw?
