crazyjr
crazyjr's Avatar
12.23.2005, 11:33 PM
working on it, want to use all the film and get it prosessed
Sylvester
Sylvester's Avatar
12.23.2005, 11:40 PM
Good, howd the assembly go?
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
crazyjr
crazyjr's Avatar
12.24.2005, 12:27 AM
It went well. you really need to follow the directions to the letter. One thing though. Put the drive cups on first before you start to assemble and it helps if you have past experience with a revo, but if you follow the directions to the letter you will be ok. One problem though, the G3 battery straps are too wide for the slits in the chassis if you have a grinding bit small enough you could make it wide enough. Not a major problem, but you need to know.
Sylvester
Sylvester's Avatar
12.24.2005, 10:52 AM
Good, i will have to follow the instructions, ill install the drive cups first, as for the slits, i dont need to use them cause im gonna run 16 cells:)
Losi 8ight e
crazyjr
crazyjr's Avatar
12.24.2005, 12:39 PM
the servo arm may hit with 8 cells on that side it will be close
Sylvester
Sylvester's Avatar
12.24.2005, 12:43 PM
I just got it, but it didnt come with those stand offs, the big ones and small :(
Losi 8ight e
crazyjr
crazyjr's Avatar
12.24.2005, 08:13 PM
I took my G2R to my LHS today to show off and try on their track (small but a track none the less) it handled excellent it has great rotation in the turns, but it is a little nose heavy. I'm running the stock revo setup so i need to work on it, but first impressions are that the Emaxx definately has competition in electric racing.
So far the reverse wiring of the motors has had no ill effects, I swaped the 64 tooth spur gear to a 70 tooth, because the G2R revo is a little heavier than the Emaxx that i ran before. Now it has better punch and no loss in speed now i need to step up to 14 cells and see what happens.
pcnutz
pcnutz's Avatar
12.25.2005, 10:31 AM
just got mine yesturday, I should have it up 4 new years
Sylvester
Sylvester's Avatar
12.25.2005, 10:45 AM
SaME here pcnutz, im already making my second order!
Losi 8ight e
pcnutz
pcnutz's Avatar
12.25.2005, 10:50 AM
I have another revo I my convert, but I did not get enough Christmass cash to pick up another hehe, I am gonna wait till after the summer to see how my first one does, I know it will be a show stopper at the track this year
Sylvester
Sylvester's Avatar
12.25.2005, 11:00 AM
Heres a pic of mine, the rear end isnt put together cause i didnt get a needed set of washers, im covered by mike though:)
Name:	for sale_e maxx 019.jpg
Losi 8ight e
Sylvester
Sylvester's Avatar
12.25.2005, 11:01 AM
^Theres a little custom work needed, not made for first time builders;)^
Losi 8ight e
crazyjr
crazyjr's Avatar
12.25.2005, 12:11 PM
yeah but not difficult, but it helps th have disassembled a revo before. I talked to Mike about the straps being too big for the slits and he assured me that they will fit, but are tight
crazyjr
crazyjr's Avatar
01.02.2006, 01:54 PM
I ran my G2R at the track yesterday after i moved the esc and turned the transmission around(spur to front), while its still front heavy it is better. Since i can't move anything else, i need a good starting setup to prevent the nose heavy attitude. I need some advise on a good setup from those with experience with E-Revo. any advise is apriciated
Sylvester
Sylvester's Avatar
01.02.2006, 01:58 PM
Well, your running 12 cells right? If your running the packs to the forward position , put it to the rear position, if you already have your batts placed more to the rear, than i dont know what to say, maybe make a little weight out of somthing to even it out, or try losing some weight with pillow balls, and turnbuckles in front so its a bit lighter up there.
Losi 8ight e
