Marvin
THE Paranoid Android
Marvin's Avatar
05.25.2009, 01:12 PM
Buggy width is about 310mm. The ST is about 430mm wide, they are not even close.
Here are two pdfs:
The ST:
http://www.cmldistribution.co.uk/pro...ed_Drawing.pdf
The 9:
http://www.cmldistribution.co.uk/pro...ed-Diagram.pdf
Ah, got you back for my useless google searches earlier!
In the beginning the Universe was created.
This has made a lot of people very angry and has been widely regarded as a bad move.
gixxer
gixxer's Avatar
05.29.2009, 11:17 PM
Made a few changes today. Took out the receiver mount and put the esc directly on the chassis. Now with 6s pack I am just under 8lbs (7lbs 15.5oz)
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
sl1
05.30.2009, 02:30 PM
I raced mine again last night with the 2200 mamba in it and it is pulling
270ma a min any ideas on another motor that will improve my run times that I don't have to turn all of the settings way down to run?
I am trying for 20 min on a 5000mah battery
FG101C
05.30.2009, 03:05 PM
Probably a 1600kv Medusa 70mm, or the 1550kv Tekin. I'm going to try the 1700kv Tekin tonight, but the smallest pinion I can fit comfortably is a 16 tooth. I'm also going to find out if the Xray XB808 42 tooth spur will fit.
Marvin
Marvin's Avatar
05.30.2009, 03:07 PM
Not really. The only way to get more run time from the motor would be to:
  1. Increase Efficieny (not easy as the Castle Motors are basically Neus)
  2. Decrease kV (and therefore speed)
  3. Go for a slightly smaller motor (but not too small, as it might not be man enough, and will cause heat buildup, and therefore decreased efficiency)
Only thing is, none of these is likely to be enough. According to your readings (270mAh per minute) a 5000mAh pack will get you 18 minutes and 30 seconds. That's assuming that the pack drains completely to 0mAh, which it won't.
I would go with some of the measures above, and a slightly larger battery (like a 5300mAh).
gixxer
gixxer's Avatar
05.30.2009, 08:58 PM
well I broke my first arm at the track today. was able to finish with some good old zip ties though.
when I got home my ebay order was here so I already got a new arm on it.
sl1
05.30.2009, 11:56 PM
did the arm split down the inside pin?
The shocks should come with these also.
http://cgi.ebay.com/Hyper-9-Upgrade-...lenotsupported
gixxer
gixxer's Avatar
05.31.2009, 12:23 AM
yup right at the pin.
I was hoping they had aluminum caps. My plastic ones are already showing a lot of where from a few flips on the street. Wish I had seen those before I order some more plastic ones.
alec2004
05.31.2009, 03:24 AM
hello
which is the smallest pinion use with the 2650KV engine ??
have combo the someone has with 4s to run ?
greats from germany
FG101C
05.31.2009, 03:41 AM
I also broke a front upper and lower arm at the track today. Of course I launched funky off a small double and smacked a 4x4 piece of wood on pit lane. The arm did split down the middle right at the pins, but honestly any buggy arm would have broke the way I hit. I also broke the front chassis "brace" part number ofn29302, but again another freak thing. I was using a t-bone racing front skidplate/bumper, it caught the dirt on a bad landing and snapped and downflexxed the chassis enough to break this part, screwed my steering geometry up and was really hard to finish the race, but I finished third.
So far I have ordered enough parts to keep me rolling and I love this buggy.
Cain
06.02.2009, 10:35 AM
had an issue with the set screw that holds part 29315 ( a little block that the center diff rear cup slides over), it was pretty stripped from the factory and I can't get it out. I'll be sending in that portion of the car after the race this sunday to see what ofna can do. Other than this, a leaky rear diff (had a similar issue with my RC8FT when new, maybe pressure change with shipping?), and the fact that whoever did the threadlocking looked like they spilled it on the front of the car it went apart and back together nicely. I like how easily the shocks assembled, and they are huge.
I went with the stock mounting location for my electronics. I removed the big outer casing that the speed passion ESC uses to get a better fit on the ESC mount plate. Here are some pics I took with electronics mounted. Rear pic showing the answerrc toe-in plate. just need to finish up the beater body. :
Marvin
Marvin's Avatar
06.02.2009, 01:40 PM
I've broken a front arm too (same split as everyone else - at the inner pin).
Apparently Hobao are working on a new design front arm.
Cain
06.02.2009, 03:23 PM
Marvin,
can you post a pic of the breakage?
jnev
jnev's Avatar
06.02.2009, 05:58 PM
So by the sounds of it, this buggy is doing pretty well other than the weak front a-arms. Would a truggy motor fit in? Or is it too long? Is the battery tray pretty secure and strong? Is it made out of plastic?
Cain
06.02.2009, 06:02 PM
the battery tray appears to be quite sturdy. Only thing to watch for is if you use long packs, the wires may bunch on the tray as its higher up than other trays.
I am excited to see what this thing can do.
