Candyman2
Candyman2's Avatar
05.27.2009, 01:18 PM
Well not quite that good, I may change it again.
I forgot to say its now just under an inch longer too, I might treat it to a new body actually.
So electronics in, took ages to cram everything in. Speedo (18.97kwf) is too big so had to trim the middle fin out for the prop to run inside it. If anyone knows of a thin speed controller that can take 18 cells/6S with over 100 amp rating and will run the 4 pole Plettenberg please let me know as the schulze gets hot!
Cut some little grooves int eh diff mount to clamp the wires in place and there we are, added some 500,000 diff oil, cant wait to run it now!
crazyjr
crazyjr's Avatar
05.27.2009, 01:24 PM
The only thing i see that might need improving, is the rear rods. I see where it'd twist under power, maybe a similar setup to the front in the rear and maybe a support in the middle if the rear setup
Lipo's would be a nice addition, but the truck is awesome and no longer a Gmaxx truck
I really got to get into school and learn CAD design
05.27.2009, 02:26 PM
Remind me to get some more Kleenex..
On the esc front, one of Lutach's items wouod be ideal- maybe a little in the wide side, but it is very flat- sure he can supply the dimensions. Otherwise I was thinking an MMM without its case/fan, or do like BrianG did and cut the top of the case off; its easily lower profile than the Schulze even with its full heatsink (famous last words).
I wouldnt mind seeing some of your other designs you were working on / drawings, just out of curiosity, but this design is pretty damn slick, rather like the BPP truggy chassis actually...
mkrusedc
NeuMaxx
mkrusedc's Avatar
05.27.2009, 03:32 PM
Just a work of art
Candyman2
Candyman2's Avatar
05.27.2009, 05:06 PM
I briefly tried cad but i'd rather draw it on a bit of cardboard and then get out there and cutting metal rather than spending hours on a pc and then getting a machine to cut it, but it has its applications for anything more than 1 offs.
I'll be making another chassis soon, more in the style of my lightning pro:
with the brace going around the motor, only reason its so hard on the maxx is the 56 spur gear is massive!
Any ideas how tall the MMM is without the case/ fan?
Joey
The Big Cheese
Joey's Avatar
05.28.2009, 04:53 AM
How much does the lightning weigh RTR? Your builds are top notch, your metalworks are beautiful!
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
05.28.2009, 10:24 AM
Wow... really nice... you sure have the custom build thing going... Have you compared the performance (power, handling, stability)
of both trucks? which do you prefer? I am glad to see someone else other than myself still using cells...
Great work man
Alien
Byte
05.28.2009, 10:36 AM
The Bigmaxx is just so beautifull!
05.28.2009, 05:43 PM
Thats what I ment, your chassis doodles on pieces of paper- an insight into the mind of a madman/genius...
As for the MMM measurements, if no-one else checks I'll measure mine tomorrow afternoon when I get home from work. Its well worth considering though, its the best esc I've ever owned, and I've had... 2 (if you dont count the mech units that came with my tamiya madbull and txt-1)...
Candyman2
Candyman2's Avatar
05.28.2009, 06:15 PM
its ok thank you, someone was nice enough to show me a case off mmm.
05.28.2009, 07:10 PM
Reckon it would work then?
Candyman2
Candyman2's Avatar
05.29.2009, 12:47 PM
yeh I think so, I might have to get hold of one.
Candyman2
Candyman2's Avatar
06.01.2009, 09:56 AM
Just finished painting my new shell
mkrusedc
NeuMaxx
mkrusedc's Avatar
06.01.2009, 11:28 AM
Originally Posted by mkrusedc View Post
Just a work of art
again!
nitrostarter
nitrostarter's Avatar
06.01.2009, 11:29 AM
again!
Had to take a couple looks again I'm guessing...
I've been drolling over this and thinking of getting a Maxx again....
N. Rustler conversion
