Best motor length / kv for 8T
medusa'd maxx
Brushless Basher
Best motor length / kv for 8T - 06.04.2009, 06:45 AM
I am doing a brushless conversion on an 8t 1.0 and I'm
going to use a medusa I use a 36 80 1600kv in my Emaxx on 6s which runs fine but for some reason seems toheat up my ESC - motor stays about 150F
ESC (MMM V3) has hit 170F
Im looking for a cool setup on 4 or 5 cells I'll be using a MMM again and I'm looking at doing some racing as well as some fast grass running (short to med length)
should I stick with the 80mm can? Ive been thinking 5S with a 2200 or 1600
any people out there tried this set up
 Send a message via ICQ to medusa'd maxx
06.04.2009, 08:31 AM
70mm should be fine 80mm would give you some extra flexibilty on gearing.
I would go with the 2000 as a compromise or the 80/1600 and gear up
15% off
medusa'd maxx
Brushless Basher
15% off - 06.04.2009, 11:31 PM
2000kv 36 80mm on its way - got to love 15% off
now all I need is a decent sized batt zippys are thin on the ground at the moment anyone got a similar priced alternative - Im after 5s 5000mah 25c or better
