Spot the Difference (you'll like this)...
Spot the Difference (you'll like this)... - 06.27.2009, 05:11 PM
Item 1
Item 2
There are only two differences, one of them very small and pretty much insignificant, the other is inexcusable (and unmissable).
10 points for each difference spotted.
scarletboa
scarletboa's Avatar
06.27.2009, 05:20 PM
difference 1: one is way overpriced
difference 2: different alarm voltages 3.3 vs 3.0
Krawlin
Got brushless?
Krawlin's Avatar
Item 1 comes with some kind of a connector and Item 2 does not.
Item one is only $4.95, while MaxCraps rips you off, charging $19.99.
Sickening.
Monster GT Conversion
06.27.2009, 05:30 PM
Item 2 does come with a connector, you just have to specify which type you want from the drop-down menu (must be a $15 balance tap connector...)
06.27.2009, 06:29 PM
boring in Devon today, is it?
06.27.2009, 06:38 PM
Just a tad.
06.27.2009, 06:48 PM
same in MN
BP-Revo
BMW M Power!
BP-Revo's Avatar
06.28.2009, 04:19 AM
Ironically, even with paying the up-the-ass shipping from Hong Kong it is STILL cheaper than buying it at MaxCraps.
TexasSP
Something, anything, nothing
TexasSP's Avatar
06.28.2009, 09:14 AM
just another reason to not buy ma.......
www.cubicle101.com
06.28.2009, 01:33 PM
Maxamps- much more expensive, buzzer is a bit smaller, no connector
HC- cheap, buzzer is bigger. included connector
eovnu87435ds
A 16yr old with a combover
eovnu87435ds's Avatar
06.30.2009, 11:19 PM
item 2 fails unless you are using a 1s lipo... 2 wires, plugs into balance harness, unless that was it's design to not check all the cells incase there was a weaker one
Hyper 7
BARBIE JEEP!!
CRT.5
TC4
RC18B
07.01.2009, 05:50 PM
Neils tip for the day:
Read the whole thread!
Both items come with a balance plug connector, but regardless, they dont measure the voltage of each cell, just the total voltage in series. You are correct in that they dont check for a weaker cell as such, just the combined voltage.
TrueRc sells a similar itemn that DOES check individual cell voltages however...
