07.03.2009, 09:14 PM
Originally Posted by lincpimp
For your setup and desired speed the 36mm can xl would be a better choice.
Just piced up a 32" mono and a mean machine cat... Less than 200 bucks for both shipped, and both have hardware... Not sure what I plan to run in the cat, but the mono will get a 14xl on 8s lipo. Most likely going to snag a turnigy hv esc, and I need another 60 amp esc for 3s usage in my mini mogli boat... Plus the big gas boat needs some work on the hardware, dual rudder conversion and fooling with the surface drive... I have work to do. Tomorrow will be a batt building day for gimpy, I have had his stuff for too long....
Sounds like a really good deal. What is the mono,just curious?
I just picked up a mini. Its a Velocity mono from minicatracing.com cool little boat, supposed to run mid 30's on 3s we'll see I guess.
"If yer not 1st,yer last"
OFNA GTP w/Quark-Medusa 60mm-5s
Inferno SP2 w/MMM-1512 2.5d-5S
Inferno St-rr w/MMM-1515 1y-5s
07.03.2009, 09:17 PM
Linc did you get anywhere with the ThunderPower packs,still good?
07.03.2009, 09:24 PM
Originally Posted by _paralyzed_
hyperion will do.......
just such a perfect opportunity
I can do that!
Not sure what the mono is. It has some damage, but that is an easy fix. I am going to custom paint the armada...
The minicat boats are good, I know you will enjoy it. I have a 13" mirco from mhz and it runs great with a 4700 28 size motor and 2s lipo. I run a mamba 25, so I even have reverse!
07.03.2009, 09:27 PM
I hope to run her this weekend, need to find a better pond the one I run now is all full of weeds.
07.05.2009, 12:24 PM
Originally Posted by nitrostarter
Great chart as a guideline for lower voltage setup's but not much help as I'm looking at going HV.
I guess all I really want to know is, is there any draw backs to going HV.
I realize lower volt setups are tried and true and probably even a few buck$ less, but in an effort to put less stress on these cells wouldn't a High Voltage setup be the way to go?
Z-Pinch racer
07.05.2009, 02:15 PM
For lowering cell stress, yes, HV will reduce it a small amount, not much.
The system as a whole will be more reliable however (usually), because of less resistive heat losses; wires, esc, motor...
07.05.2009, 09:23 PM
So since I've got one of these kicking around
http://www3.towerhobbies.com/cgi-bin...&I=LXHYK6&P=ML
do you think it will cut it for the 10s setup if I add watercooling or just not enough?
Z-Pinch racer
07.05.2009, 10:40 PM
Hmm, that would be pushing the limits of that ESC pretty hard. I don't really know how Kontronik rates their controllers vs. realworld, but I would say a ~80amp continuous controller is what you need. But you never know, you could just try this one out for a while, go easy on it, check the temps and keep pushing it until you are satisfied. Water cooling system just might do it though.
07.05.2009, 10:50 PM
I have one sitting in an e-Raptor converted heli that I'm not using.
I think I'll try it out on a small prop & watch the temps.
Z-Pinch racer
07.05.2009, 11:18 PM
yah, do that, cuz with water cooling, you tend to need a less rated current capacity compared to surface vehicles. Try it, and report back with temps, and the go from there.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
