Hacker C50 Maxx specs?
Byte
Hacker C50 Maxx specs? - 07.17.2009, 03:04 AM
I'm wondering which specs the Hacker C50 Maxx has. I can't find it on their site eighter. I would like to know:
- Shaft size
- KV
Could somebody answer these questions or give me a link where I can find the specs of this motor?
Thanks,
Patrick
OZ-RUSTLER
OZ-RUSTLER's Avatar
07.17.2009, 03:21 AM
I am fairly sure that they have 3mm shaft and 3600kv.
snellemin
2 KiloWatt RACER
snellemin's Avatar
07.17.2009, 03:35 AM
The motor came in 3 different kv's. 1/8 shaft for the older ones and 5mm for the newer ones. Old data can be found at aircraft world---> http://www.aircraft-world.com/prod_d...ets/hm-C50.htm
C50-MAXX 12 12 Cells3600Kv 15/72 pinion/spur set
C50-MAXX 1414 Cells 3300Kv 15/72 pinion/spur set
C50-MAXX 1616 Cells2600Kv 15/72 pinion/spur set
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
Byte
07.17.2009, 04:34 AM
Ok thank you!
But it's still a bit strange that you can't find any information of them on the Hacker site.
othello
HV basher
07.17.2009, 06:18 AM
This pdf might help
EDIT: The Maxx is not listed in this pdf but the c50maxx can still be ordered according to their 09 pricelist. But i couldn't find any specs on the german website either. Seems as if they are phasing it out of their product portfolio.
Byte
07.17.2009, 07:06 AM
This pdf might help
Yes I already saw that. They've got it in their pricelist (225 euro) but not in their C50 pdf file. I just e-mailed them why the C50 Maxx isn't on their site anymore (except the price)
steveo
07.18.2009, 09:18 AM
look under car products they offer the c-50 for 1/8 which i think i saw listed as a 13L motor at one time good thing is it has a 5mm shaft which you need, i snapped of the 3.2 shaft
if interested i have a c-50 14.4 motor less the rotor which you could get from hacker and have a good motor less than the cost of new
snellemin
2 KiloWatt RACER
snellemin's Avatar
07.18.2009, 10:34 AM
The Maxx motors use a shorter magnet then the L-size motors, but the motor cans are the same. The metal sleeving inside is also shorter in the Maxx motors then the L-size motors.
