Feigao heat problems.
Kyosho
Feigao heat problems. - 07.21.2009, 12:28 PM
First thing i need to clear up. I know feigaos arent great, i know i should get a new motor, i know, i know, i know.
Now, In my CRT i run a feigao 10xl, MMM, 5s zippy, 11/46, and diffs 43/13. and my tires are 5.6in without ballooning.
temps within 7-10mins are:
Motor-140* 145* F
ESC- fan turns on at this point or it also hit 165* on me.
Batts at this time-86*F
So on Beat your truck i was informed that i may be under geared, so i had a 14t pinion laying around so i tryied it.
temps after 5-7mins:
every thing the same give or take a degree or two, but it heated up faster.
With 11/46 its geared for 38MPH
14/46- 48MPH
I cant gear any lower because the mounting slots stop and the motor cant move over any farther.
any sugestions?
and when i get a new motor i want around 38MPH on 5s, so i would get like a 1600kv motor. but i cant get a motor that is any wider than the feigao because it will hit the center diff out put, so i would have to get a medusa 80mm 1600kv motor, geared 12/46
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
07.21.2009, 12:33 PM
140-145 isn't hot!
Metallover
RC-Monster Spudgunner
Metallover's Avatar
07.21.2009, 01:41 PM
You should be good up to about 160f, then you have to worry. Get the medusa you mentioned. It will blow the fiegao away.
Kyosho
07.21.2009, 01:46 PM
its not the motor im worried about, its the esc getting so hot, i have it mounted up high and it has lots of air flow. but i think its the motor making it hot, i now 140 is a good temp, but its gets there so fast, i only have to put about 300 to 400 millie amps into the battery to charge it because the esc just gets hot and i cant run it.
nitrostarter
nitrostarter's Avatar
07.21.2009, 02:19 PM
What are your settings on the ESC. This may play a large part in the heat problems. Things like timing, start power, etc...
N. Rustler conversion
Kyosho
07.21.2009, 03:25 PM
timing lowest for 2 pole motors.
start power is low. i never try to wheelie or do huge burn outs or any high power starts. im easy on the throtle and slowly get up to about 3/4 throtle before i run out of room and have to turn around.
07.21.2009, 03:37 PM
A couple more points
1: What is the ambient air temp? If it's ~100*F, that's actually not a bad temp
2: Temps that rise fast but do not get much higher is nothing to worry about, as long as the temps don't keep climbing higher and higher. For a given surface area, any material can dissipate so much heat. The hotter it gets, the faster it dissipates (up to a point of course). At some point, the rate at which the temperature increases will slow and stop as there will be a balance between the delta between ambient air temp/material temp, and the rate at which the motor case dissipates heat. Also, fast rising and falling temps simply means there is efficient transfer of heat.
3: High ESC temps usually means overgeared. I know you say you can't gear lower due to physical constraints, but is it possible to increase the spur size? Or maybe get a diff ring/pinion that is geared lower (not sure how the CRT is set up)?
4: Assuming you can do something to gear lower somehow, I personally would not get a 1600kv motor for 5s. Some may disagree. 1600kv on 5s is under 30k rpm, and when geared for ~40mph, may cause the ESC to stutter a bit at startup because the motor is spinning relatively slow per mph and the ESC may not be able to get rotor positioning feedback as easily at lower rpms.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
07.21.2009, 03:48 PM
Listen to Brian, he knows what he's talking about! Also I have a 36-70-1600 Medusa and a 1515 2.5D (1650kv) and run them both on 5s with great results. Low speed power is fine and top end is incredible! On my RC8T I can gear it down to at least 30MPH, I race with it geared 50/15 or about 35MPH, fast enough to pull on the nitros and slow speed cogging doesn't exist
blueb8llz
07.21.2009, 03:54 PM
have you tried changing your motor timing to normal?
Kyosho
07.21.2009, 04:45 PM
ok, so if i get a 2000kv medusa geared 11/46 it will be. 46mph this is alttile fast for me. and to go with a lower diff ratio i would be spending close to $150, the air temps here are about 86*F, I live in Canada.
if i get the 1600kv motor it will be geared under 40mph, about 36mph with 11/46 gearing.
I dont drive Wide open all the time, i barely even get up to full throtle.
here it is with the medusa 1600
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 11
Total Voltage: 18.5
Motor KV: 1600
Tire Diameter (inches): 5.8
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.006
Spur/Pinion Ratio: 4.18 : 1
Total Ratio: 13.83217 : 1
Tire Circumference (inches): 18.22 inches (462.82 mm)
Total Motor Speed: 29600 RPM
Vehicle Speed: 36.92 mph (59.31 km/h)
Effective KV Value: 1600
KT constant: 0.85 oz-in/A
07.21.2009, 04:50 PM
IF you are happy with ~36mph, the relatively low kv of 1600 should be fine. I wouldn't gear much higher though for the reasons I stated earlier.
$150 to change the diff ratio? Wow, that's a bit pricey! Have you checked the ebay chopshops, or is that the retail price? 3.3:1 diff ratio is typically used for buggies, so it makes sense now. Truggies typically use a 4.3:1 ratio which allows more flexibility with spur/pinion gearing. And since you didn't say, I assume there are no larger spurs available?
Kyosho
07.21.2009, 05:04 PM
I am using the CR buggy mount and a larger spur probaly wont fit. and i cant find any 43/10 diffs for cheap, the only ones that i was informed worked were the LSP diffs wich are about $70 (canadian) each. the CRT uses 43/13 diffs, like buggies.
my track is pretty small so a low top speed is what i need.
Kyosho
07.24.2009, 03:32 PM
will the medusa 80mm 1600kv motor on 5s geared for 36mph be good? i want an effecient setup that runs cool.
will the esc be cooler?
nitrostarter
07.24.2009, 03:46 PM
Definitely! More efficient as well than the Feigao!
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
07.24.2009, 03:56 PM
Yup, that'll work. And later on you can gear it for 72mph and not have to change anything!
