Just go Play
Just go Play's Avatar
08.14.2009, 04:47 AM
After being away from the forums for a while I was looking forward to catching up on the latest products and such. Sadly I could not resist checking this thread out only to discover what looks to be a clone of the last debate around MA's latest product release.
For me the most disappointing things about this thread is that Austin no longer seems genuinely interested in addressing customers concerns with his product. The response given to BrianG's example of a specific and documented problem with MA product was appalling and more like something I would expect from Jason... I believe I have lost any respect that I had for Austin previously.
As for 3rd party testing of any of MA products I would not hold my breath. If I recall correctly the last time someone did that (with prior consent mind you) they were threatened with legal action if the posted test results were not removed.
Austin I'm certain that nobody enjoys having their company/product/person put down or portrayed in a negative manner, who would?
But if you are going to ask for specific examples of problems your customers may have had with your product in a public forum have the decency to acknowledge the ones that reply with valid documented concerns. If you are no longer willing to do so that is ok too. Just don't come around asking questions you don't want answered.
I do get a kick out of the advertising claims of the "best this" or "most powerful that". Very amusing stuff...
Dafni
Dafni's Avatar
08.14.2009, 04:51 AM
Just go Play, I agree with you on all you said.
I felt the same after I read the thread. Haven't bothered to follow the MA story here lately, just came back to research some batt stuff, read this thread, and felt exactly the same as you.
lutach
lutach's Avatar
08.14.2009, 01:12 PM
Good thing my 2 3S 3000mAh MA packs didn't burst into flames. If anyone saw the pics I posted, they would see the packs were very close. I'll see where I put them and post them here again.
hoober
08.14.2009, 06:35 PM
I personally think Mike has enough on his plate. The last time I talked to him, he said he started growing another set of arms to keep up with the workload.
As far as what should be tested; I think the ratings should be substantiated at the very least. And provide the voltage per cell at that rating along with the temperature.
We can (in addition to substantiating ratings) simply test at various levels of current. In other words, who cares what the rating or label says. Run the pack at 20C,30C,40C,50C and 60C and allow the voltage graph to speak for itself. Anyone can call it any way they see it. This process will in itself substantiate the ratings even if the operator has no idea which pack is being tested at the time.
08.14.2009, 09:29 PM
I would say to pull the pack down from full charge to 3v per cell (maybe 10 amp load?) and see what the capacity is. The done the load tests at 10-20-30-40c, etc. That way you do not need to even look at the label on the pack, just go by the data that you log. So you will get a real world capacity and current ability. Some oscillating tests from 1c to 40c over a few seconds, then repeated would also be interesting, just to see pack performance. Also noting pack imbalance after load testing would be handy.
whitrzac
Can't catch this...
whitrzac's Avatar
08.14.2009, 09:33 PM
OHHHH, I want it
hoober
08.14.2009, 10:02 PM
I agree, very meaningful tests.
Novak hv6.5 watts
bcltoys
Novak hv6.5 watts - 08.23.2009, 08:32 PM
Novak lists there hv6.5 at 730 watts is this surge watts please help me understand i stupid.
whitrzac
Can't catch this...
whitrzac's Avatar
08.23.2009, 08:40 PM
it means that its a low power motor...
08.23.2009, 08:54 PM
I believe that would be maximum continuous watts, most BL motors I've looked at for typical MT or 1/8 scale use are in the 900watt upto 1500watt range.
The novaks are still pretty good at shifting lighter weight stuff, and dont consume as much go-juice in the process compared to say an MMM or Rx8 etc.
However, DO NOT GO BY THE SURGE WATTS RATING ON MAXAMPS LIPOS AS ITS TRIPE, AND DO NOT TRY TO CALCULATE HOW MANY SURGE WATTS YOUR SETUP WILL USE AS ITS NEAR ENOUGH IMPOSSIBLE.
Use common sense (if you have any) and read around to learn about proper lipo choice for any given motor/esc/vehicle setup- there are zillions of threads here, so use the search button.
Or just buy a pair of 30c 5000mah 2s lipos from hobbycity.com.
bcltoys
08.23.2009, 08:56 PM
Im trying to understand maxamps surge watt rating with the hv6.5 motor as this is the only brushless motor i have to compare to there surge watt bs.
bcltoys
08.23.2009, 09:19 PM
Must have writing at the same time as you Neil will the hobby city batts cut the mustard in and erevo with the hv6.5 that weighs in at 13 pounds.
08.23.2009, 09:21 PM
You wont be able to, as like I said, its near impossibble to tell how many watts your system is developing under acceleration (surge) without the use of an EagleTree data logger or similiar item. Even then, you may not capture the largest spikes with total accuracy, as it samples the current and voltage (volts x amps = watts) every 10milli-seconds I believe, so you may only catch the start of the spike of the tail end of it.
Typically, I've seen spikes in the 120-130amps region for normal BL setups running 4-6s lipo, so thats somewhere in the 2000-3000watts region. A decent 4s 25c 5000mah lipo can deliver 1800watts, or 6s 2700watts, which is pretty much fine- the hvmaxx being a less powerful system will draw somewhere around 80% of what a 1000watt motor will do. Thats an educated guess though, havent seen many, if any Eagletree sessions carried out on a hvmaxx- might be a question for the novak techs perhaps, though I imagine they will just give you 'on paper' ratings rather than real world test results, which is understandable.
Buy the best batts you can afford at the end of the day.
08.23.2009, 09:24 PM
Wow, its like you travelled back in time and stole my setup from a few years ago....
The lipos will be fine, but you will find that the motor cant physically produce enough power to move the truck faster than about 25-30mph; all the lipos in the world cant make up for a lack of torque, so you have to geare down to prevent the esc melting from the high current draw; thats from directly compareable experience, so believe me when I say you need to either loose some weight off the truck (about 3lbs), or step up to a bigger BL system...
coolhandcountry
coolhandcountry's Avatar
11.14.2009, 04:45 PM
Wow what a catch up.
I don't really understand this surge wattage rating.
My only problem was a packed that puffed up and I had to buy another to replace.
I would like to see some kind of test results myself.
Peace!
Country
Help support the
Rc-Monster
Buy here
