Need help with E-LST2 gearing...
JAILBIRD
Need help with E-LST2 gearing... - 08.26.2009, 09:00 PM
I'm just finishing up on an LST2 conversion and need a bit of help with the gearing. I'm running a CC2200kv/MMM combo with a 6s 5000mah 30C lipo. The spur is a 63t. I also have the TD collet hub and the Losi FOC. What would be a good pinion to start with? I'm not looking for absolute top speed, just a good ratio for bashing and showing up some nitros. Thanks for any help!!
-JB
Here's a quick pic.
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
08.26.2009, 09:11 PM
i'd start with 17-18t. awsome, awsome looking build btw.
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.26.2009, 09:12 PM
Use this handy dandy tool to figure out your top speed, gear fpr 40mph.
http://www.scriptasylum.com/rc_speed/index.html
TexasSP
Something, anything, nothing
TexasSP's Avatar
08.26.2009, 09:27 PM
I have the same setup geared for 50. Don't remember my exact gears right now but that's where I am at and everything runs cool. I am using the TDR colleted pinion adapter on mine along with the TDR motor mount.
www.cubicle101.com
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.26.2009, 11:02 PM
Duder Rocks.
Don't forget your RPM shims for the C-hub Right Front.
Nice LST2 BTW.
Byte
08.27.2009, 04:01 AM
I'm still messing with my LST... It's got an 2-Speed. The motor (Plettenberg Bigmaxximum) stays cool like a fridge. But my ESC (Quark Airmaster 125B with externel BEC) gets hot like fire after 10 minutes... :( I'm running stock gears, so 18/70 and 25/63. And last time I mainly ran in 1st gear, so why does my ESC get so damn hot? :S
Sorry for the off-topic a bit, but this will maybe also help you to decide for a good gearing. The Bigmaxx has 2300kv, so its like a Mamba 2200kv...
YogyBrushless
08.27.2009, 05:14 AM
what tires are runing and do u have FOC with gear swap ?
i`ll be running the same motor/cntrlr combo on 5S with stock wheels and tires and FOC + gear swap using 25t pinion to get around 45mph.
__________________________________
Must Find Cash For RC
KaztheMinotaur
KaztheMinotaur's Avatar
08.27.2009, 06:58 AM
I'd say 15 or 16. I ran my LST2 with stock gearing, 18/25, on 5S with a Neu 1515/1Y
jas21373
08.27.2009, 07:15 AM
hi mate ,I ran a Medusa 2000kv in mine ,with 63t spur and a 30t pinion,very quick and wheelies on demand.Left nitros for dead.
this is a vid with a Fieago 10xl on 6s lipo
[YOUTUBE]JZ8qDLu7MXI&feature=player_embedded[/YOUTUBE]
Klausen
Brushless G-maxx
Klausen's Avatar
08.27.2009, 09:47 AM
I just made more or less the same conversion, but on an Aftershock. I am also using the TD motormount, but still the 2 speed stock gearing, which is 63 spur and 25 pinion. I haven´t fully tested it, but seems to run pretty good.
What will I need to run single gear. Is it only the single speed hub from TD?
JAILBIRD
08.27.2009, 06:14 PM
Thanks alot for the help. Can anyone explain or point me to a good article about rollout? I used the speed calculator link above (thanks Bondonutz!), and it says a 22t will be 1:1 rollout. I'm not realy sure what this means. Also, the tires are 40 series big joes.
jas21373, nice rig!
Klausen, all you need for the single speed is the TDR hub. It is a direct bolt-on.
-JB
Klausen
Brushless G-maxx
Klausen's Avatar
08.28.2009, 10:39 AM
Super thanks. What kind of spur do you use?
