Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
50T spur does not fit
wallot
wallot's Avatar
Exclamation 50T spur does not fit - 09.01.2009, 04:05 PM
Just started to put new slipperential for my friends RC8T and looks like the 50T spur is not machined properly as the teflon insert does not ift (well it does with some brte force) but then the gear does not fit onto the diff cup.
I did check the gear with caliper and internal diameter differs by 0.1-0.3mm if I go around the spur.
can I fix it with bit of dremeling or should I ask Mike for replacement as I know i wont be able to dremel it exatly to the tenth of the milimeter and it will wobble?
My existing 46T spur does fit nicelly.
Bad day. first the RX8 now the spur.
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
09.01.2009, 05:35 PM
The 52t spurs are a little tighter (not really a bad thing, but it is more difficult to install) - here is a quick suggestion, though:
Replace the bushing on your 46t spur and take the slightly used Teflon bushing from the 46t spur and use it on the 50t spur. This will work like a charm. :)
Also, if you are measuring .1mm - .3mm out of concentricity on the inside of the gear, I suggest you get a new caliper - the blanks were turned on a cnc Haas lathe and should be concentric within +/- .02mm - no way they are out of round by .1mm(maybe on the 46t gear, which is cast, but not likely on the cnc'd 52t spur).
wallot
wallot's Avatar
09.01.2009, 06:16 PM
a little?
your tip worked great and I am glad i had to remove slipperential from mugen as it was really dirty and needs fresh oil after 2 races.
Radek
*EX-10 Eurus*
simplechamp
simplechamp's Avatar
09.02.2009, 07:09 PM
What is suggested for people who don't have a worn-in teflon bushing to swap out for the new one? I haven't assembled my 50T slipperential yet, but am curious what to do in case I run into the same issue.
RC-Monster Mike
Site Owner
09.02.2009, 09:36 PM
The bushings are tight in the 52t spur, but they still fit. They are more difficult to get onto the diff cup, but not impossible. The effort will be woth it, though - a tighter bushing will wear better/longer.
09.02.2009, 10:48 PM
"Tighter is better" Old Indian wise saying!
