Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
riverat1540
riverat1540's Avatar
04.15.2009, 08:00 PM
really that thick?
i was thinking 50 would be plenty, as i only run 30k in my crt. 200 seems pretty thick maybe id try 100k first
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
Unsullied_Spy
Unsullied_Spy's Avatar
04.15.2009, 08:22 PM
I think I'd go for the thicker fluid because it will loosen up over time, and I like my diffs pretty solid.
riverat1540
04.15.2009, 08:27 PM
do u have the aluminum cases? oil that thick can cause things to flex under high speed slip situations. but thanks for the tips i think i will start at 50k and adjust from there
Unsullied_Spy
04.15.2009, 08:33 PM
Mine are the stock plastic cases, they seem to be pretty tough so I haven't bothered with aluminum cases.
04.15.2009, 08:46 PM
I am using the hd cases in the the center and rear. 50k fluid is like water... Not sure if I have a bad batch, it is thick as all hell in the bottle but it feels like nothing in the diff... Maybe I need to make sure that it is slap full? It must be at least 90% full now.
riverat1540
08.27.2009, 08:34 PM
Thought i would post an update my muggy is almost complete i just need to get rid of my 1515 1y and get a 1521 1y or even a 1521 1.5d would be cool. so here are some pics minus motor ill be running turnigy 5000 6s 30c should be pretty sweet, i swapped over my crt motor mount and it fit well and lets me use my top plate for my esc. was running it on 5s zippy h and the 1515 1y but it was causing the batteries to go to crap and eventually it did, they were just old zippies plenty of use from the truggy and beat pretty hard for a 15c pack,lol but i think i like the muggy more than the truggy plus the parts are cheaper and i dont have to buy a whole sheet of parts to get a wing mount.
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
jayjay283
jayjay283's Avatar
08.27.2009, 09:05 PM
I run a CC 2200 in mine on 5s and 6s and its never overheated. I cant remember the pinion but I think its a 25 and a kyosho 45t spur. It was those big old tires that was killing mine. Best upgrade I did to it was on the top of the bulk, furthest rear wing mount put in 1 size larger (cant remember dang standard sizes) and 1/2" longer Tony screws. I land that thing on the wing (most jumps) and it just takes it. Really made the rear strong.
Unsullied_Spy
08.28.2009, 02:41 AM
The wheels and tires are what really kill the Muggy in terms of performance but I like it with those big tires on it. I put Rulux wheels with Badlands on mine and I don't like it that way, I liked it better as a big, lumbering monstrosity. The stock tires lasted me over a year and were still alright but 6s power was enough to rip them to shreds.
If you keep the stock tires the 1515 should be plenty, but a 1521 is going to be crazy even with the stock tires. I'd look into running a 1Y on 4s or 5s just to keep it tame enough to use.
riverat1540
08.29.2009, 01:27 AM
yea im pretty tame but love the power on tap and like to show off a lil bit when im just having fun, ive ran it on 5s with a 2200 and know it needs more power for what im comfortable with but maybe 5 s would be good for the muggy with a 1521 but its a big truck and deserves a big battery, i know it inside and out and am not afraid to do rebuild it if it breaks i just love the break neck speed of raw brushless power and want to show it off with my muggy
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
Unsullied_Spy
08.29.2009, 06:50 AM
A 1521 is more powerful than that motor^
Plenty of power on tap won't be a problem for a 1521, keeping the tires in 1 piece and keeping the front wheels on the ground will be. Throttle control is everything and having power to spare is nice, so if you can keep it tame enough to use then that's a great motor! The Muggy is a very tough truck. If you put the diffs in the LST aluminum cases and keep them well-greased they put up to a LOT of abuse and despite how hard I've beaten mine the entire drivetrain is still solid. The only failure mine has had so far was the front diff because the plastic case cracked and let the ring and pinion slip.
A stock Muggy with RPM arms and Lunsford titanium turnbuckles in the arms is almost indestructible. The aluminum diff cases and the new arms are really the only things I've done to mine as far as durability and despite being beaten mercilessly on a constant basis it continues to hold up to the abuse very well. The Muggy is an excellent truck, after seeing mine my LHS has finally decided to start stocking them
riverat1540
08.29.2009, 11:23 AM
yea the lst cases were the first to go in. i might have found a motor on another forum im waiting for the guy to get back to me
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
riverat1540
09.07.2009, 10:24 AM
Well i got my battery yesterday and decided to give the 1515 1y a chance so i could at least see it run on 6s, i got a 11tooth pinion which was the smallest that would fit without center brace trimming. well i was suprized how great it ran, peak temp after hard grass running was 168 wheelies to no end. i can copy unsullied spy's back fip no problem actually it was the first thing i did after i saw everything was rolling smooth. its faster than it can be controlled top speed and im very happy with my build. battery temp got up to 110 with turnigy 30c 6s 5000mah. mamba fan ran alot but that is to be expected. its amazing to see something so heavy flug around like a ragdoll. the only problem i have is over excessive tire ballooning in the front even with 100k in the center. but i have some spiderwire fishing line im going to wrap on the tires to see what happens as i ripped a tire open when it ballooned and hit the body. but i replaced it and still have 2 more spares
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
Unsullied_Spy
09.07.2009, 11:07 AM
That sounds hot for a 1515, but I suppose on 6s in the grass it sounds right. In that video I was running a 16T pinion, 6s certainly has potential for some serious power. Your Muggy is coming along quite nicely, any plans to go with RPM arms though? I snapped stockers all the time until I finally dished out the money for RPM arms. Just beware that you will need Lunsford turnbuckles for them, the stock ones bend and shear very easily.
09.07.2009, 12:33 PM
Looks good. Why do you have the ESC mounted there and not behind the battery?
riverat1540
09.07.2009, 03:44 PM
i was always told to stay under 180 with the neu motors. but it wasnt nearly as hard on it as it was the speed control, which went in flames today so ill get the mamba replaced, and wait for a medusa 80m 2000 to roll around or my ideal motor the 1521 1y. ill post pics later, the reason the esc is so high is that my top plate for my jammin crt mount i have in there from my truggy, it has a esc mount on the back so i figured better up high than right in everything i kick up, so im on hold now, bur it was running great, just uder too much pressure so a bigger motor is the way to go. ill post pics later it was a little fire ball untill i disconected the battey and blew out the flames. the truck died, i took the body off slid the switch to off then back on and it suddenly caught fire so there must have been a short somewhere thank god my new battery didnt go up as well.
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
