Dafni
Dafni's Avatar
01.19.2006, 04:45 PM
This past summer I spent a 2 week RC holiday almost only on Responses. Many long sessions on tracks included. Had no problem, but I wore them out good.
Just don't drive them when the foams are wet. The additional centrifugal force will rip them no problem. Also the rubber is so thin, I can see a single small cut or hole will lead to rubber flapping all over the place.
Sylvester
Sylvester's Avatar
01.19.2006, 05:18 PM
Alrighty, hope they do good for a custom racetrack:)
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
01.19.2006, 11:19 PM
They will do fine for most applications. Promod and Coolhand tend to like the extreme end of the power scale. I haven't blown a set of responses yet(though I have seen it happen!). A rip will surely lead to failure, but for a 14 cell setup, they will likley last you quite a while.
Sylvester
Sylvester's Avatar
01.26.2006, 06:12 PM
I have got some news and pics, i finally ran the g2r, for 3 mins only but it was AWESOME!!! Why only 3 mins? My one battery pack went POOF! pics; http://www.rcpics.net/img/72400
http://www.rcpics.net/img/72401
http://www.rcpics.net/img/72402
http://www.rcpics.net/img/72403
Losi 8ight e
Sylvester
Sylvester's Avatar
01.29.2006, 08:54 PM
I got her up and running again, im just doing the cycle process with the batteries, everything looks good so far, 1 Q, my esc seems to be getting hot, but i dont think it is over or under geared , im running 14/70 on 14 cells, doesnt that sound about right? more pics coming soon!
Losi 8ight e
crazyjr
crazyjr's Avatar
01.29.2006, 09:43 PM
I'm currently using 18/66 gearing on 12 cells, for 14 i would suggest 16/66 for starters
Sylvester
Sylvester's Avatar
01.29.2006, 09:46 PM
Im not sure if i should gear up though, because my speed is already insane! It has good accel and fast top speed. Hows your g2r crazy? Anything u'd like to share?
Losi 8ight e
squeeforever
squeeforever's Avatar
01.29.2006, 09:53 PM
insane? with titans? you might not want brushless....:027: :027: remember, a brushed motor wont heat up from being undergeared. i think :032:
boss 302
01.29.2006, 09:59 PM
squee-sometimes a brushed motor does heat up when it is undergeared
sylvester-if this is any help a stock emaxx with titans has an 18t pinion and a 66t spur but i dont know the diffs are in a revo i believe that an emaxx has 13/37 gears in the diff(correct me if im wrong)
Sylvester
Sylvester's Avatar
i have never been on 14 cells, only on 12, its a big step for me, but BL WILL startle me for sure!
Losi 8ight e
squeeforever
01.29.2006, 10:03 PM
the revo diffs are the exact same ratio as the emaxx. sylvester, try a 16 tooth pinion.
Sylvester
Sylvester's Avatar
01.29.2006, 10:07 PM
will do , this truck is probably a little fast because it is pretty light! it weighs under 9 lbs..... ill get a weight soon.
Losi 8ight e
boss 302
01.29.2006, 10:47 PM
a 16 will do but like i said the emaxx uses an 18t pinion and a 66t spur
Sylvester
Sylvester's Avatar
01.29.2006, 10:49 PM
yes it does, but on 14 cells traxxas reccomends to gear down a tooth or 2.....
Losi 8ight e
boss 302
01.29.2006, 10:55 PM
im pretty sure it is only 1 tooth but that is just what i was told and i thought you said you were only running it 12 cells
