Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
Freezebyte
09.17.2009, 03:05 AM
Do you need 3 channels to power this? Like on a Flux? Does it turn on at a certain temp or run all the time? I'm intrigued, despite fan haters like Brian
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
09.17.2009, 03:16 AM
cool....or cold, idea...but like brian...i still dont like fans
  Send a message via MSN to shaunjohnson
brushlessboy16
brushlessboy16's Avatar
09.17.2009, 06:43 AM
It’s always better to reduce the heat generated in an electric power system is by better engineering than to try and cool things with fans and other gimmicks. Sure, a fan can get you a few degrees, but it is much better to have a superior design to begin with.
Contradiction?
Whats the flow rate of the fan?
bcltoys
09.17.2009, 07:26 AM
Use at your own risk,your just covering up a problem. Not geared right.
FastXR
09.17.2009, 08:14 AM
Will the blower work on a non-finned original Neu 1515 motor?
simplechamp
simplechamp's Avatar
09.17.2009, 09:40 AM
There's a big difference between using a fan to make a hot, overgeared setup barely usable, and using a fan to keep a cool, properly geared setup even cooler.
09.17.2009, 09:50 AM
Agreed, but some don't realize this...
Foxracin
09.17.2009, 10:27 AM
If you have a batt port where bec or receiver pack plugs in and you are not using it you can run it in there.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
09.17.2009, 10:45 AM
u speeky no enrish two me!!!!!
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
sabongi
would it work on a tekin t8 motor?
big greg
09.17.2009, 03:24 PM
gear it up!!!!!!!!!!!!
Freezebyte
09.17.2009, 10:29 PM
Castle, whats the official word on this, me likey fans to keep things cool despite what the fan haters think
sikeston34m
sikeston34m's Avatar
09.17.2009, 10:32 PM
You can run a fan off ANY unused port on a receiver.
They all have power for as long as your receiver has power.
big greg
09.17.2009, 10:55 PM
its all about the plug, most likley it would come with a rx plug
simplechamp
09.17.2009, 11:17 PM
I would say it's more about the voltage rating. The plug can be easily changed, but you are stuck powering the fan at the specified voltage. I would guess it's a 5V fan so it can run directly off of the receiver though, and it would follow that they would use a standard RX/servo connector. I don't see why it would be anything else than 5V.
