Maxxrickard
Maxxrickard's Avatar
09.18.2009, 03:51 PM
how big are the UE springs?
i need springs with:
outerdiameter: 19mm
innerdiameter: 16
length:80-100mm i believe
JoFreak
JoFreak's Avatar
09.18.2009, 06:11 PM
no, the front shocks are not going to be too short, on the contrary: for several shock towers the rear shocks are going to be too long.
I would start with the recommended oil as well, and as far as I know you get the heavier oil in the front shocks and the lighter oil in the back shocks.
Maxxrickard
09.19.2009, 03:09 AM
okey. 70wt front and 60 in the rear?
but i have the harder spring in the rear?rookie....
if i dont find harder springs is it possible to use longer springs?i will by a set of fron/rear spring and will use the front spring, but if they are to soft in the rear i maybe can use the rear springs in the rear....
will it be more firm if the are longer?
JoFreak
JoFreak's Avatar
09.19.2009, 07:13 AM
only if you use progressive springs, if you use normal springs it won't work
Rivermaxx
09.19.2009, 08:41 AM
In my experience ofna springs are too soft you need UE supershocks springs. 2 black and 2 blue.
Maxxrickard
09.19.2009, 10:31 AM
hmm thats not fun...
is it still possible to buy them?anybody have 2 blue and 2 black for me..?
how big are UE springs?inner/outer diameter?
billytruck said he will get back too me 28:e sep. hope he have..
Maxxrickard
09.20.2009, 03:38 PM
i reallt starting to like the UE shocks, but i cant find them anywhere...
if billytruck dont have 4 shocks i really must by the ofna shocks. but the ofna hard springs seem to be to soft.
i find "Associated Shock Springs Extra Firm Copper MGT" looks good
"...Supports 6.90 pounds of pressure." is that hard enough?
JoFreak
JoFreak's Avatar
09.20.2009, 05:38 PM
don't get this the wrong way, but how often do we have to repeat: the UE supershocks are the same as the ofna shocks which are identical to the jamara shocks I posted a link to a few posts ago
Rivermaxx
09.20.2009, 09:50 PM
Just buy some traxxas big bores and be done with it.
Maxxrickard
09.21.2009, 01:15 PM
okey, sorry guys...
yes i can buy big bores, but i really would like to use 4 shocks
i can buy the jamara/xixcr shocks but the problem are the springs. i cant fint extra firm springs...tips?
is it possible to use 4 big bores?
JoFreak
JoFreak's Avatar
09.21.2009, 03:18 PM
in that case, you didn't even look for other springs:
took me like 2 minutes to find
and now go and find the hardest springs you can find in the store...
Maxxrickard
09.21.2009, 03:29 PM
yes i have find them. but they are to soft...
JoFreak
JoFreak's Avatar
09.21.2009, 03:37 PM
how do you know that they are to soft?
allready tried them?
Rivermaxx
09.21.2009, 07:02 PM
Yes, I have tried them,Understand a mt is quite a bit heavier than a buggy or truggy. They will work but not like UE ss springs.
Maxxrickard
09.22.2009, 01:49 PM
thank you guys for your patience. thank you guys for all suggestions and tips.
i will not buy ofna or traxxas big bore.
thanks US for ebay. i am a happy owner of 4 UE supershocks NIB with 4 black and 4 blue springs.
