1/8 Sensored systems
Jabe
1/8 Sensored systems - 10.07.2009, 05:05 PM
Which is best in performance, reliability and price-quality relation?
This list is just random order.
  • Team Tekin
  • Novak
  • Hobbywing/Speed Passion
  • LRP
Discussion with argumentations...
Is there more 1/8 sensored systems that are on market currently?
Marvin
THE Paranoid Android
Marvin's Avatar
10.07.2009, 05:15 PM
The LRP has only just been released, so don't expect much in the way of feedback. In my opinion, the ESC just looks like an SXX with a fan and some new stickers. Only 4S capable.
The Novak ESC is a little dated now, and the motors don't really come with a useable kV for 1/8 buggies and truggies. Again 4S limit.
The Tekin ESC is good, bearing in mind it hasn't been out that long, and so Tekin haven't been able to iron out all the little problems yet, much like the MMM. The motors, however, I cannot recommend. Yet. I've had a couple of rotor failures. I've got some new things to try (slipperential and gearing up), so I'll reserve judgement until then. 6S capable though! Tekin are really trying to look after anyone with ESC/Rotor failures and are being quite quick with help and advice.
Hobbywing/Speed Passion. I'd just skip past the SP part and just get the Hobbywing stuff - it's the same, but cheaper. This combo is by far the cheapest out of the four. I don't have much experience with the motors other than to say they feel very small. They are only the same diameter as a normal 1/10 motor, just a little longer. 80A Hobbywing is 4S capable - same as the SP, but the 150A HW is 6S capable. Also comes with a quick programming card, which is very easy to use and makes adjustments a breeze. To make use of their warranty, be prepared to send it back to China for extended periods, should anything go wrong.
In the beginning the Universe was created.
This has made a lot of people very angry and has been widely regarded as a bad move.
10.07.2009, 07:42 PM
Q. what vehicle are you thinking abot putting the system in exactly/ overall setup?
Jabe
10.08.2009, 05:55 PM
Im asking in general.
But my plan is to put it in XT8 with 4S or 5S probably 4S.
Are those sensor cables standard? I mean can i use e.g. Tekin esc and LRP motor?
10.08.2009, 06:13 PM
Most sensor cables are std, however I cannot see using anything other than the tekin motors. You plan to run a truggy on 4s, you will need all the torque you can get. The 2 pole novak/etc motors are not as good as the tekin. Any reason you have to have sensored?
Jabe
10.09.2009, 05:41 AM
Sensored for smoothnes and precision.
My plan is still to get RX8 combo, just asking about that sensorcable fit.
Marvin
Marvin's Avatar
10.09.2009, 05:37 PM
I just found some details on the LRP SPX8 ESC, which kind of destroys it in my eyes.
SPX8:
BEC / Electric power supply of the receiver: 6V/5A
Weight: 45g
Motorlimit: None
Voltage Input: 7.2-14.8V (2S-4S LiPo)
Rated Current: 764A/Phase
Type: Forward/Brake/Reverse
Standard SPX Bullet Reverse:
Weight 45.0g
Motorlimit over 3.0T (Brushless) / over 4.0 (Brushed)
* Brushless + Brushed: Forward/Brake/Reverse + Forward/Brake
* Automatic brushless/brushed swichtover
* Internal-Temp-Check System
* Advanced digital with 4 adjustable modes
* Big power capacitor optimised for Touring car application
* Ice Drive Design
* AutoCell System - Automatic NiMH-LiPo adaption
* Voltage Input: 4.8 - 7.4V
* Low-profile heat sink
* Fan on/off via speed control main switch
* 25 years warranty
* 3x Multi Protection System
* German Technology
Hmm, they are both 45g. Can't be that much to improve the voltage capability to 4S, a new BEC design maybe? Some different Caps?
Also, what's with the crap '764A per phase'? 'Cos that's likely!
10.09.2009, 07:34 PM
That specs allows you to correctly determine the proper maxamps pack to buy. Jut match that number to the "ratings" that MA have an you are good to go.
I read it as 76amps per phase at 1st glance, and thought that was a bit overrated...
Jabe
10.10.2009, 07:29 AM
So that would be 3x 764A= 2292A!! Now thats what i call salesman talk...
Lets give others honor to burn first LRP esc's. Can anyone confirm that are LRP motors 2 or 4 pole?
Is there any other 1/8 sensored systems?
Marvin
Marvin's Avatar
10.10.2009, 04:04 PM
Lol, and agreed, I had to do a double take at that. I knew LRP overrated their ESCs, but I didn't know that it was by that much.
The only sensored 1/8th systems out there are the ones already mentioned. Unless you include Nosram, which is just LRP in red.
Lauri
10.13.2009, 07:01 PM
The SPX8 doesn't even have better BEC - still 2S LiPo BEC. You have to connect the ESC to 2S voltage input by a sperate wire. That's something new, weird. Check out the manuals of the SPX8 and Vector8 at www.lrp.cc
My CC BEC handles up to 10S, LRP SPX8 handles up to 2S for BEC and only 4S to power the motor. Whaz going on?
But the size and weight look nice. Also the different design of the Vector8 - high kv, 13mm diam rotor and 275g total weight (thats 100g less and even more)
10.13.2009, 07:37 PM
SPX8 isnt a 1/8 esc, its a 1/10 TC system that just so happens to work on 4s lipo, so they stuck a new label on it and called it 1/8 scale, as has already been discussed.
himalaya
himalaya's Avatar
10.15.2009, 12:20 AM
Now comes CC MMpro, designed for 1/10 scale though. I have no doubt it will run great with 6S + low KV motor on a 1/8 buggy.
....What a Blue Sky....
