motor mount
relaxed
motor mount - 03.14.2005, 11:05 AM
i have just taken my motor mount off because it is such a pain to swap spur gears,and as i am experimenting i need to be able to change these easily. I am using the stock mount at the moment and just wondered if any one had any idea's or thoughts on this
Sylvester
Sylvester's Avatar
03.14.2005, 12:04 PM
what tooth spurs and pinions do you have?
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
relaxed
03.14.2005, 12:21 PM
I have a hv maxx and novak suggests 70/14-16 so that along with i have a 72 spur and the stock gearing this is what i am playing with at the moment
MaxxFusion
MaxxFusion's Avatar
03.14.2005, 12:27 PM
Why would you want to swap Spur gears? It is much easier to swap the pinion. Once I put a Spur gear in I leave it and change my gearing with the pinions.
  Send a message via MSN to MaxxFusion
relaxed
03.14.2005, 12:35 PM
i am not the most knowligable person on gearing but i wanted to find out the differences if there were none surely novak would have suggested 66/.....and the only way i thought i would find the difference is by experimenting,if there is a short cut to this knowledge iwould welcome it
MaxxFusion
MaxxFusion's Avatar
03.14.2005, 01:15 PM
There are some other guys on this forum that run the HV. If Novak is suggesting a 72T Spur I would go with that and then you can play with the pinion size. Start with their recommendations and then you can go up or down a tooth size to fine tune the gearing for your needs.
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
03.14.2005, 06:26 PM
I agree with Frank. I would stick to a single spur and change the pinion for experimentation. Each tooth change on the pinion is equivilent to a 3 or 4 tooth change on the spur. If you change the spur from a 66 to a 72, it is almost like dropping a tooth on the pinion.
