Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.16.2009, 07:59 PM
I find out when I cross that bridge, I hope to start on that after I make a few much needed repairs on a few other trucks. Maybe in a couple weeks ?
bdebde
That's All Folks!
bdebde's Avatar
10.16.2009, 11:03 PM
That sounds like a good idea. Less weight than a tranny and you could use the slipperential. I haven't looked at the truck to see if it would work but instead of mounting the motor over the diff could you cut a hole in the top chassis plate and mount the motor beside the diff?
I had a quick look at Brian's calc. The pinion would need to be much smaller, 11-12t.
I was thinking the center diff and motor might fit more in between the top and lower chassis plates, the diff could moved off center just like the 8ightT ?????
Motor above the diff works well. CD mounted to custom bottom plate, fits right up in the tranny hole, slight filing may be needed around the outdrive cups. Gearing would be quite limited with stock F/R diffs, which is why I will be using Muggy diff gears to give a little more choices. I will also be using a 48 - 50t spur (12/46 shown) to give further gearing options, although 11/46 fits current configuration.
ID:	7869   Click image for larger version
ID:	7870   Click image for larger version
redshift
RC-Monster Square Tube
redshift's Avatar
10.16.2009, 11:56 PM
^That schitt is CLEAN bdebde^
Center diff/center spur FTW
pinkpanda3310
pinkpanda3310's Avatar
10.17.2009, 08:20 AM
Are the muggy diffs a straight swap bdebde?
jas21373
10.17.2009, 08:34 AM
muggy diff cases are the same as Lst diffs,muggys have 43/11 crown and pinion ,you may want to try Sportwerks Mayhem Turmoil diffs they also are a direct fit and have 43/13 crown and pinion.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.17.2009, 12:55 PM
Looks interesting, I feel a little inspiration.
bdebde
That's All Folks!
bdebde's Avatar
10.17.2009, 01:30 PM
Yes muggy diffs are a drop in to the lst2 cases, Sportwerks are as well; and you can use Mayhem ST TiNi gears for bulletproof muggy ratio. Running that in my muggy.
pinkpanda3310
10.18.2009, 10:28 AM
I just saw a mayhem 45t ring gear, will that fit in the lst diff case? Also with the pinion, does it need to be matched with the ring gear or can I just swap the pinion 11 to 12 to 13?
bdebde
That's All Folks!
bdebde's Avatar
10.18.2009, 06:50 PM
You will need the 45t ring gear and the 11t pinion to match it, and they will fit right in the LST2 cases
10.18.2009, 08:43 PM
I'm doing the same thing with my LST. One regular LST and one LST XXL driveshaft seem to give the right length for a center diff in an LST. It almost falls together!!
jzemaxx
10.20.2009, 11:48 AM
Coolest setup I've seen so far....
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
pinkpanda3310
10.21.2009, 06:40 AM
That's the set up Bondonutz was thinking of. Looking at it now, I would like to see how he mounts the batteries and I notice he has only one steering servo, I would like to know how that works too. Maybe it's with a muggy assembly
It does look neat cutting out half the top chassis but
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.21.2009, 11:32 AM
Single servo on the LST is easy and works very well.
jzemaxx
10.21.2009, 03:32 PM
I run a single servo as well....just like above with a JR8711
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
JAILBIRD
10.21.2009, 05:34 PM
I want to do this but one question, why no servo saver?
