Metallover
RC-Monster Spudgunner
Metallover's Avatar
08.18.2009, 11:54 AM
Got some testing done. This thing is a beast. I took it down to some smooth road. It crashed under my friends car, almost under a running lawn mower, and in front of a moving van. This thing too 5 or 6 crashes at full speed and I didn't even break a part. It's heavy, and I expected to break something, but never did.
Holy crap. It looks over 40. really. I think I go out of range though, so I need to work on that. Yeah, I didn't get a video. Sorry. I might be able to get one by the end of the week.
I think there's a rock in one of the motors so I'll have to take it apart and clean er out. I'll do both while I'm at it. The mount needs some work too.
And, I think this estimate is pretty cose
Differential Ratio: 1
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 1
Pinion Tooth Count: 1
Total Voltage: 7.4
Motor KV: 1500
Tire Diameter (inches): 1
Tire Ballooning (inches): .25
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 1 : 1
Total Ratio: 1 : 1
Tire Circumference (inches): 4.71 inches (119.69 mm)
Rollout: 4.71:1
Total Motor Speed: 11100 RPM
Vehicle Speed: 49.53 mph (79.57 km/h)
Effective KV Value: 1500
KT constant: 0.9 oz-in/A
Metallover
Metallover's Avatar
10.24.2009, 07:55 PM
I decided to continue the perpetual project today. I got the motors off, and I saw one of my wires was disconnected. Maybe that's what was causing the cogging... Insted of trying to repair the motor, I think I'll go ahead and rewind it. By what I've read, I should be able to get a higher turn for less kv and more power due to tigher packing. I really need the low kv because the thing is so overgeared...
I am considering buying some magnet wire over at gobrushless.com, but I don't know hou much I need or what gauge to get. Can anyone chime in here?
If you know a good tutorial for winding an outrunner, let me know.
Also, rewinding the motors might cause a differnt kv for each motor. It's a risk I'll have to take I guess..
And here are some pics of the motor
10.25.2009, 04:21 PM
Contact MTXMUGEN on here or aim.
Metallover
Metallover's Avatar
10.25.2009, 04:33 PM
I've been chatting with ron_van_sommeren and jdetray on RCU and they gave me a ton of good imformation - http://www.rcuniverse.com/forum/m_17...tm.htm#9200941
My heart is pretty much set on getting some wire locally, probably 22 gauge, and terminating in a star config. That should give me hopefully around 1000-1500kv. That's a solid 20mph on 2s lipo which should be very controllable. Also the power and efficiency should be way up lenghthening runtimes and hopefully improving startup.
Next time I take it trip into town I'll stop by radio shack or similar and pick up some magnet wire. I was going to go with gobrushless.com, but I figured it would be easier and faster to buy locally..
10.25.2009, 06:26 PM
I'd gear for 30ish if I were you, you'll get quite the torque geared for 20...
Metallover
Metallover's Avatar
10.25.2009, 06:54 PM
I went and got some magnet wire. After I replace the dryer vent hose I'll attack rewinding the motor. I'll get some pics up too.
No clue how much speed I'll get. It depends on the kv I end up getting, and I have no clue what that'll be.
10.25.2009, 07:01 PM
How much was the wire?
Dryer vent hoses... Oh I remember those....
Metallover
Metallover's Avatar
10.25.2009, 07:53 PM
The wire was about $6.59. I got three rolls. 40' of 22g, 75' of 26g, and 200' of 30g. I will have lots of the smaller wire if I need to have more turns.
Metallover
Metallover's Avatar
10.25.2009, 09:51 PM
An hour and a half down. One stator clean. First 6 teeth took about 15 minutes. Next two teeth took about 45 minutes. Last tooth took 45 minutes and some serious concentration and anger management. There was some sort of epoxy or glue on the one tooth. That stator suffered a little damage, but I think it'll be ok.
I'll start winding probably tomorrow with the 26awg wire. Turns out 26awg is probably the exact size the original windings used. I hope to be around the 1000-1200kv range.
Here are some pics
And I found I was geared for 75mph with the old 2300kv.
Thomas
Thomas's Avatar
10.26.2009, 06:04 PM
Just found this thread. Nice setup! Is the receiver an integral part of the motor mount?
Metallover
Metallover's Avatar
10.26.2009, 06:19 PM
Nope, just strapped onto it. I am replacing the motor mount and possible the chassis too because the motor mount was too weak. I'll have to find something else to make the motor mount of out.
redshift
RC-Monster Square Tube
redshift's Avatar
10.26.2009, 09:34 PM
Gives ya a whole new respect for the woman who probably has to do about 40 of these per hour.. when you really think about what's involved, $8 seems all but impossible. If these were made in the US (haha) they would be ten times that much.
That takes some real patience. One of my most memorable nightmare projects was lacing my own wheels for my mountain bike. That was over 20 years ago... you guys just have one carbon spoke now- it's a lost art!
Very cool project and I hope you get those motors REAL close in kv!
Steering trim might not fix more than about 2% variance.
Good luck little China girl...
Metallover
Metallover's Avatar
10.26.2009, 09:37 PM
I have even more respect now, after I tried to wind it. Half hour wasted in 3 attempts. I'll read up some more and give it another shot tomorrow. If you can wind a brushless motor,,, That's impressive.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.26.2009, 09:53 PM
Seriously, I thought I had incrediable pateince. I don't think I'd have it for winding those tiny motors with my big fat fingers. Keep up the great work and good luck to you Riley
03.12.2011, 02:46 AM
Ever finish your winding?
