Fat Kid Engineering
09.18.2009, 07:31 PM
Originally Posted by lambchops
does look good that!! should cut down on 90% of the dirt i would think. you going to add any cooling holes to the shell now there is less airflow through the body gap?
Thanks Lamy
Yeah, Probably elect to do the big hole in the front glass like a Nitro Fuel tank access.
09.30.2009, 09:45 PM
10.20.2009, 04:05 PM
Jeff i tryied to post a pic of how i vented my body over at the hurricane forum. nut it would'let me . so i'll post it here . This is how i vented mine .
Fat Kid Engineering
10.20.2009, 04:14 PM
I like the oval holes, different and gets the job done. I'll try that next time.
Thanks
10.20.2009, 04:59 PM
Thanks
Your welcome  . I like it as well because it provides plenty of venting . Plus it still leaves alot of the winsheild for support. . I used a sanding drum from a dremel .
silly nitros....
10.27.2009, 07:23 PM
Not to hijack your thread, but I've got a couple questions for the 9e owners. What differential oil do you run, and what brand (theres so many choices). I also would like to know what body is a direct fit, if any. I have searched around with no luck. All help is appreciated.
"Every time I hear/see a nitro motor, I actually get angry" -BrianG
10.27.2009, 07:28 PM
For the diffs, 5-5-3 front to rear is common I believe. that is what I am running.
For bodies, if you want something that fits tighter, you can try the Hot bodies VE8 body, and mount up the Tekno mudguards for a nice fit from what I have read on RCtech.
Fat Kid Engineering
10.27.2009, 07:59 PM
+1 on the diff weight.
Cain, I have nothing on my schedual Weds(clean slate!) I will be getting your chasis done 4 U.
10.27.2009, 10:04 PM
Thanks!
THE Paranoid Android
10.28.2009, 06:31 AM
You guys may be interested in the Hyper 9 2.0 updated parts:
Click me!
Apparently there are some new front lower arms too...
In the beginning the Universe was created.
This has made a lot of people very angry and has been widely regarded as a bad move.
10.28.2009, 09:18 AM
good find!
10.28.2009, 12:00 PM
I never had a problem with anything other then the front arms. Good to see them making improvements, but I will hold off on upgrades for now. With how fast they seem to make changes the parts will probably be updated again before my racing season starts again anyways.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
10.28.2009, 01:44 PM
yeah, thats the bad thing with all the fixes, its great they are coming out, showing they are not just sitting on the issues, but, at the same time, its kind of hard to keep up with them too.
I am going to just keep running the vehicle I have in its configuration with my spares, and upgrade when needed, or, must buy another car when they release the latest spec version with the upgrades present. By then, the car probably will be ready for a refresh.
Fat Kid Engineering
10.28.2009, 02:16 PM
I broke a front arm, nothing else. Ben beating the shiz out of it too !
Linear Mode
