redshift
RC-Monster Square Tube
redshift's Avatar
08.27.2009, 03:23 PM
Are none of you worried about motor overheating due to being underworked?
Seems like it could be an issue for extended intervals at crawl speed, I dunno.
What do you guys think, are there issues with BL other than cogging in a semi-crawler setup?
Just curious here....
TexasSP
Something, anything, nothing
TexasSP's Avatar
08.27.2009, 05:01 PM
Originally Posted by ticklechicken View Post
EDIT - I called CC. The MM Pro is 1/10 scale only. They don't have any immediate plans for a 1/8 sensored ESC.
The MM Pro will work fine in 8th scale in your application. The MM was 10th scale and used all day long in 8th scale applications on 4s and 5s. it's the amp draw you have to worry about anyway. Check out the CC forums here, there is a whole thread on the MM Pro.
www.cubicle101.com
coolhandcountry
coolhandcountry's Avatar
11.06.2009, 07:56 PM
Did you find any thing that worked well for this?
One of the smoothest systems I have found is a quark with neu 1512 2.5d 2000 kv motor.
Peace!
Country
Help support the
Rc-Monster
Buy here
ticklechicken
11.07.2009, 10:47 PM
I got the 2250kv Tekin system. It works very well. Unfortunately, the motor only lasted 3 battery packs before dying. I just received a new motor a few days ago. I really hope this one lasts.
padrino
hmmm...
01.22.2010, 10:21 PM
I'm looking into a MMM or Tekin solution for my Summit, how did the new motor work out for you? In addition to that please share the details on how you waterproofed it (referring to earlier post)
ticklechicken
02.06.2010, 11:22 AM
The Tekin is working great. They replaced my motor quickly, so no problems there.
Here's my first attempt at waterproofing:
Here's the unfortunate results:
Here's my latest attempt:
My current method is working fine so far.
