RC-Monster Square Tube
12.17.2009, 10:51 PM
Originally Posted by JThiessen
From my experience with people that work in the machine shops, Grizzly products are priced low for a reason - but these guys are used to running machines that hold +/-.0005" over 4'.
Jet Equipment is usually considered a step up from Grizzly, and their prices reflect that.
Are you going to be machining steel? Do you need a coolant system included on the machine, or will you apply it manually?
In the end, you want repeatability, some amount of accuracy (is your slot going to be a slot, and is it positioned properly relative to whatever you wanted it to be). The ability to do this will determine if you end up using it. Also, the ability to change speeds easily. If its a cumbersome operation to change your speeds, you will end up leaving it set on whatever you last had it set for, and likely use your dremel to cut that new part.
Like Nitrostarter said, your vices and cutters will make or break you!
Gosh you make it sound like Grizzly stuff is banged out in a backalley lol. I have not worked with Grizzly equipment per se, but I have had a close look at some of their woodworking stuff. It is very well made, far cry from HF.
Jet machinery I have heard a lot of mixed opinion on. I have run a few Jet lathes, and I guess I am indifferent on the ones I've run. Neither great or horrible....
Ok, prepare to be bored by some annoying logic.
Unless linc is looking to make turbine shafts, the larger equipment is not of much use to him. A combo machine will do the job of 3 and take up the space of one. CNC stuff is great, but for getting a feel for things, you actually need to feel it. You need the mechanical connection to the work, some real feedback. Starting with an NC could be quite dangerous, if not to the operator, then to the machine itself. And for one-off jobs, I certainly wouldn't want to program anything, that defeats the purpose.
Used equipment is a gamble, you may get a good one, or you may get one that's looser than Pamela Anderson on an average Saturday..
For spot cooling, Koolmist units are the cat's ass.
We are talking about hobby-to-intermediate level, which is why I recommended the Grizzly units. Their prices on tooling and accessories is also very reasonable, and they would have at least 95% of it in house. One stop shopping!
12.17.2009, 11:09 PM
Damn, there goes my idea of a fully portable, turbine powered lipo charger...
I understand the "feel" aspect of getting the hang of making stuff. I work with my hands on a daily basis (yeah baby, do I make you randy?!) and am pretty good at visualizing stuff and getting it made with my crude tools. I am also a good steel welder, no experience with other metals though, no need yet.
So the combo machine looks good, although a small cnc would be nice, like the one Jeff linked to in covington (a few miles from me). Wish I had the funds (well I do but they are earmarked for firearms and ammo) to buy both. I just need to jump in and buy something, find its shortcomings and then upgrade!
This is all great info, keep it coming! I bought a few books on running machine tools and have some ideas about how it is done.
Fat Kid Engineering
12.17.2009, 11:16 PM
With what I do for a living I have a lot of basic stuff at home; Miller 110v Spool gun(can weld aluminum, SS, reg steel) , Smoke wrench, Plazma cutter,Compressor, small sturdy work bench with nice large vise and my giant tool box. But all this stuff fills my shed up, Don't really have a decent work area or any room for more toys. Hopeing to afford some day to level my old work shed and build(or have built) a much larger work shed with A/C to add all the goodies as this thread is partaining too. Right now I do 99% of my RC work in my bedroom(thankfully its a large room at 18'X20' w/bath), but all of the cutting and grinding gets done outside in the shed. Pipe dream I guess, but someday it'll happen ?
I envy anyone whom has a garage and the funds to put the nessasary tools and extra goodies to keep a hobbist in a orgasmic state.
I'd give one of my nutz for a 2 car garage and a sweet lathe/mill.
Something, anything, nothing
12.17.2009, 11:34 PM
Originally Posted by rchippie
James why dont you just get a used bridgeport ?.
Damn straight. A proven design that has lasted the years. You cannot go wrong with a bridegport CNC mill or manual. The great thing is that the head on all is interchangeable. Just be careful on the used machinery and make sure the ways are not going out as at that point it's better to just replace the machine.
Most of the cheaper machines can only handle small jobs and do not have good duty ratings. I looked into everything I could several years ago for my machine shop I managed and it always came back to bridgeport. I found some nice deals on 5-10 year old cnc machines.
12.17.2009, 11:39 PM
To use welding as an example, it's 75% proper machine settings, etc, and 25% user skill.
In that same vain, standard machining is 3/4 proper feeds/speeds/tool selection, and 1/4 skill.
James if you are adept at welding thin gauge steel with minimal distortion, welding heavy gauge (ANY metal) will be a walk in the park.. Welders almost always begin with gas (oxyacetylene) brazing, then welding. So you are probably much better prepared than you think.
Tig is the only process I actually enjoy, especially stainless. I have to have projects to keep myself from getting rusty. I did a full exhaust for my bike back in '05, 100% 304, from the flanges back, even the baffles are SS. Full freeform as well, no blueprints were used.
One of these combos would be priceless for gun mods, or reproduction parts- as if you hadn't thought about that aspect hehe.
But really you are only concerned with different materials' characteristics, and keeping all that info in your brain.
A quick example would be, you don't cut steel with toolsteel.
It will work, but there is not enough hardness differential between the cutter and the stock, and your edge will dull fast.
It's not difficult at all, and the best way to learn is simply experimenting with materials and tooling.
12.17.2009, 11:42 PM
I do agree that a bridgeport with a knee? would be a great machine to own!
As for welding I learned with a mig, welding sheet metal on cars. I can weld pretty well and have done some crazy stuff, none of which can be repeated here...
Anyways, I have wanted to get into machine tools for a while, so I guss a decent mill would be a great start... I will look around the classifieds to see what is up.
12.17.2009, 11:47 PM
well, Linc likes to experiment
12.18.2009, 11:39 AM
Your exactly right on that - we often get caught up in wha tis the best versus what will do the job.
Originally Posted by Bondonutz
...now I do 99% of my RC work in my bedroom.
!!!!!!!!!!!!! WOW!
12.19.2009, 12:56 AM
+1. At my job over the years I have been able to talk my boss into buying a lot of equipment so that we could start building a lot of the componets we usually have made by other vendors in house because we were not getting the quality we needed. That and having parts made at weld shops, sheet metal shops and machine shops caused us a lot of oops moments. That's when I said we needed a fixit machine so we bought this:
http://www.harborfreight.com/cpi/cta...emnumber=42827
While it's not a high quality unit we have had this one for almost 5 years and other than a leak around the seal of the spindle its been a trooper. Over time as needed I got a Wilton 1310 Vise, Tbolt and hold down set with step blocks, parallels, dial indicator and a host of end mills. I bought a coolant pump at wholesale tool for $65 and use the Cool Mist coolant. That stuff works fine other than alge grows in the tank after a few days of not being used wish I knew how to fix that. Funny thing is I use the same thing in our bandsaw and it never does that. I do most of the prototyping at my job so I use this machine a lot and the finish is just fine as long as you don't need anything closer than .001".
When we decided to start doing our welding in house I searched around and got this one:
http://www.millerwelds.com/products/tig/syncrowave_200/
One of the things you have to worry about when picking a welder is how much can your wiring handle. I noticed that some of the guys had 300 amp welders listed but they need a 61 amp service at 230V which unless you have a 200a service will pretty much suck the breakers into the insulation at full tilt. We originally bought a 230V unit and after looking at the specs it needed 54 amps at 230V. I had to make a 75' run to where the welder was going to be so I needed #6 wire X 3 (2 hots and a ground off of 230V 3ph). At the time copper was through the roof and you have to buy a minimum of 500'. We ended up returning the 230V unit and getting a 460V unit. That way I only needed 27A and 10ga wire.
We do about 80% SST most everything is at least 304 and some 316. SST is weird to weld it moves around so much. The frames we were getting from our vendors were more than 3/8" out and football shaped. When we started making them we were able to keep them under 1/16". SST is my favorite, since it's clean and leaves all the pretty gold n purpley beads. We use only Argon on this machine even when we do mild steel. I use Silicon Bronze if it's got to be pretty when welding mild steel.
For welding mild steel frames and sheetmetal drive gaurds, and being portable I got a Hobart Handler 140:
http://www.hobartwelders.com/product...ed/handler140/
It's about the biggest 110 powered Mig you can get (Lincoln and Miller have comparable units as well, Hobart and Miller are in cahoots). One thing I wish it had is a variable amp setting (more fine than just 4 steps). It works great on up to 1/4" in a single pass but it pops a 20 amp breaker after about 30 seconds of cont. welding on the highest setting. I have found that if I plug it in to the Miller it works fine  .
I have been asking for a plasma for a while maybe next year.
Jeff
12.19.2009, 02:28 PM
[/QUOTE]=J57ltr;339772 That stuff works fine other than alge grows in the tank after a few days of not being used wish I knew how to fix that. Funny thing is I use the same thing in our bandsaw and it never does that. [/QUOTE]
Dang it, I've run across that issue before. Let me do some checking and see if I can find an answer for you.
Linc, are you looking at putting something in your garage, or you body shop? He made a good point with the electrical service requirements - a big machine is going to be wired in, as opposed to the "portable" equipment.
12.19.2009, 03:33 PM
JT and jtr, we use an algaecide additive, coolant can go rancid pretty quick. Not sure what brand, but you can do a search for algaecide/bacteria inhibitor additives. It does work wonders, the same coolant that would get to stinking in days is now good for months, at least.
RC-Unobtainium
12.19.2009, 06:14 PM
Diesel algaecide can work also...not ideal though (some are flammable)
Enhanced Rustler 1515 1.5 MMM
Losi 8ight-T
12.20.2009, 02:34 PM
The most popular home use mill to convert to cnc is the Seig X3 sold by both Grizzly and Harbor Freight (as well as some others). There are several kits to do it yourself, as well as tons of info on Cnczone from users who have done so and are producing parts that far exceed the tolerances required for our parts.
If you want a mack-daddy rtr cnc setup that is still single phase powered so you don't have to mess with phase convertors or have three-phase power, then the Tormach and the Industrial Hobbies machines are probably the two most regarded.
Destroyer of Tires
12.21.2009, 10:37 PM
When you said "larger" machine tool discussion you guys weren't kidding. I'm going to have to keep an eye on this. One day I'd like to upgrade from the Dremel, Chicago electric 110v MIG, grinder, etc. But the Drill press, cheap 2 axis vise, and milling bits have gotten me by pretty good so far for my hobby stuff.
12.21.2009, 11:43 PM
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
