starscream
RC-Monster TQ
starscream's Avatar
02.03.2006, 04:10 AM
Hey DAF,
The spur is a 46t mod 1 gear from the MGT. The strobe kit will work great, it just requires a little material be removed from the chassis for gear clearance.
Thanks for the shock socks tip. :cool:
The brake lever bends a touch but gets the job done effectively. I'm focussing on my G2R for racing now so I'd like to get a center diff installed in the tmaxx tranny soon.
Ha Ha
Dafni
Dafni's Avatar
02.03.2006, 08:28 AM
I can't wait to show you mine.
Serum
Serum's Avatar
02.03.2006, 08:38 AM
Boys.. boys... Behave.. those sexuals acts.. (still have got this clear visual of you dancing naked on the table...)
I think it will FLY Daniel.. A 1950, on 6S lipo, and with that little weight!
Dafni
Dafni's Avatar
02.03.2006, 08:44 AM
:dft002: OMG, what were you thinking!
LOL
Yeah, the 1950/7 will be killer on 22.2V. I bought an 8 turn with 6S in mind. And the 6 turn is awesom on 14 Ni cells already.
crazyjr
crazyjr's Avatar
02.03.2006, 03:39 PM
Starscream. Nice to hear from you again. Is the slipper an Associated Monster GT unit or a Traxxas unit? If Traxxas, How did you go from the hex shaped shaft to a pin design for the Revo?
starscream
RC-Monster TQ
starscream's Avatar
02.03.2006, 05:01 PM
crazyjr,
The revo tranny input shaft is actually the stock emaxx input shaft. I removed the steel gears and installed the plastic revo gear. It works quite nicely. The gear is for the MGT but the slipper plates are from the t/emaxx.
Ha Ha
crazyjr
crazyjr's Avatar
02.03.2006, 08:38 PM
Cool, I thought about that but never tried it. You're the first person i've seen here that thinks like i do.
MetalMan
MetalMan's Avatar
02.03.2006, 10:35 PM
I use a MGT spur on a Revo slipper assembly. Works quite nicely when 3 of the slipper peg holes on the MGT gear are bored out to 5mm, it fits right onto the Revo slipper assembly just like a Revo gear!
crazyjr
crazyjr's Avatar
02.04.2006, 04:55 AM
Shoot the Tmaxx gears bolt right on, the Mgt should without drilling
starscream
RC-Monster TQ
starscream's Avatar
02.04.2006, 05:03 AM
Cool MetalMan,
I actually made a revo slipper adapter for the plastic 44t ofna pirate10 spur gear. I used this on my single speed emaxx tranny with a center diff.
I looked at using the revo slipper with the tmaxx tranny but it was more work than I wanted to put into it. I got the strobe adapter from Mike and am very happy with it.
Here's some pic's of the emaxx single speed center diff tranny and spur adapter... starscream style:
Yup, thats the revo input shaft in the emaxx tranny :D
I actually used shoegoo to keep the diff from leaking but then found I needed to shim the internal diff gears a bit so I had to take it all apart again :035:
I thought this was a pretty simple solution for a single speed emaxx tranny with a center diff. I'd like to do something like this with the tmaxx tranny but the t-tranny offers a few extra issues to tackle.
Thanks goes to Mike for the center diff adapter.
Ha Ha
squeeforever
squeeforever's Avatar
02.04.2006, 12:29 PM
were did the gear come from?
starscream
RC-Monster TQ
starscream's Avatar
02.04.2006, 04:12 PM
I assume you mean the blue diff gear?
I got the 13t and the blue 36t gear from sdp-si.com
I also got some 36t gears from Mike as well
I stuck with plastic gears to keep the weight down. I've run all plastic gears in all my trannies with my brushless setups and never had a problem so far.
I chose to utilize the 1st gear gear-set (13/36) because I was running a small spur gear with the revo slipper. This setup would be an easy conversion just using the stock input gear with the steel gears. If your going to use a larger spur gear, I'd use the 2nd gear gear-set (18/31).
I have a set of gears comming for the tmaxx tranny 26/28. This conversion is a little tricky but do-able.
Ha Ha
crazyjr
crazyjr's Avatar
02.04.2006, 06:39 PM
Is that a T/Emaxx diff? and, Could a revo diff be adapted to this setup? Because i have a few and could use one without losing spares
BTW Starscream. Where do you live, if you don't mind saying
starscream
RC-Monster TQ
starscream's Avatar
02.05.2006, 03:03 AM
The diff is from an Ofna hyper 7 buggy with a custom spur plate.
It's possible to modify a Revo diff to work as a center diff but due to the design of the diff case, and the solid pinion shaft, it will be more difficult to adapt.
Ha Ha
crazyjr
crazyjr's Avatar
02.05.2006, 01:19 PM
Thanks for the info Starscream. You said mike has the plate to seal the diff and to mount the gear to?
