gtxracer
HOOH HUAH HOOH! Aww Baby!
gtxracer's Avatar
12.22.2009, 03:06 PM
Ah, I see. I put in 30K I believe, which has been much better. My front and rear probably needs more fluid, it's about time for a change. I want to put 10K in the front and like 4 or 5K in the rear. I was also thinking about 7K up front, I'm not sure which would be better.
It's going to be different with each setup. I run a direct drive setup with motor brakes and a slight drag brake so I don't have to slow down much using the trigger in corners. The droop helped tremendously. My front end was so high when accelerating that I could hardly control where the truck was going when on power in corners. This is the first 1/8 scale that I've actually fine tuned for racing, so it's been a fun learning experience.
:D
gtxracer
gtxracer's Avatar
12.23.2009, 11:59 PM
Put 7K in front and 5K in the rear, seems to be awesome. Won the electric 1/8 main tonight :)
:D
George16
Supermaxx
George16's Avatar
12.24.2009, 12:09 AM
Congrats!!! That's what I run on my ST RR. What do you have in your CD?
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Rampokker
Rampokker's Avatar
12.24.2009, 12:11 AM
Well done! Sounds like you've got the setup sorted then.
gtxracer
gtxracer's Avatar
12.24.2009, 12:28 AM
Thanks guys! I believe I'm running 30K in the center, I'll have to look again since I can't remember. I think this is the setup to have in this truck for my driving style, which is pretty aggressive and I like to drift around corners sometimes. Drag brakes help too
:D
gtxracer
gtxracer's Avatar
12.24.2009, 02:54 AM
Pic of the track I was on...very big to me-
:D
George16
Supermaxx
George16's Avatar
12.24.2009, 03:52 AM
That's a nice big track!
Revo with OS .18TZ
gtxracer
gtxracer's Avatar
12.24.2009, 04:07 AM
Yep, let's me get wide open on the throttle in a few places, I love it! I need to buy more batts though, running 4s 5000 packs only gives me about 12 min runtime on a track this size.
:D
Rampokker
Rampokker's Avatar
12.24.2009, 05:45 AM
Looks like an awesome track! I'm pretty sure I've seen videos on youtube from this track... How long was your final?
12.24.2009, 09:29 AM
Well done! I have changed my diff settings around/experimented and settled w/ 20F 20C 7R. Almost no unloading and since I don't race it works well.
gtxracer
gtxracer's Avatar
12.24.2009, 01:00 PM
Thanks guys! It's a well known track, tons of vids of it out there. For electric nights, th quals are 5 min and usually the mains are 8 min but we only did 5 last night due to time. I had a faster qualifying time since I put it in cruise control after lap 3
:D
