George16
Supermaxx
George16's Avatar
02.19.2010, 08:37 AM
Email or give them a call. I posted the number in one of my above posts.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
superek4
superek4's Avatar
02.19.2010, 11:17 AM
How do I open a neu motor? Took out the 4 screws but the rear seems glued.
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
George16
Supermaxx
George16's Avatar
02.19.2010, 07:31 PM
Smack it with a mallet.
Revo with OS .18TZ
superek4
superek4's Avatar
02.19.2010, 08:01 PM
R u kidding? Smack the back or the shaft?
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
02.20.2010, 05:05 AM
Hit the shaft at the front of the motor- that should pop the rear endbell off just like a feigao. Then again, you might punch the shaft out of the middle of the magnet- unlikely though, and you can just claim it happend while running the motor normally..
superek4
superek4's Avatar
02.20.2010, 05:40 AM
Wow seems that I will damage the motor if done wrongly.
Seems that neu motors has wires problems. I m thinking of tekin wo wires.
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
02.20.2010, 06:01 AM
The neu design is ment for helis & planes mainly, in those vehciles the motor wires arent subjected to forces manking them vibrate and wiggle up and down constantly- thats why castle took the design and changed it so that the wires dont/cant get damaged and short against the can.
You can always slide some insulation over the wires and into the can a little bit, that will prevent them shorting out- depends on if the enamel coating on the wires is also damaged & causing the individual strands to short against them selves in each main wire...
superek4
superek4's Avatar
02.20.2010, 06:20 AM
Problem is I m using neu tekno square can meant for cars:(
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
02.20.2010, 06:49 AM
Meh- the only difference between that & a normal Neu is the shape of the can pretty much, no changes made to the way the wires exit the can, though the can is sealed better I must admit. I think your only real option at this point is to contact Neu, explain the issue & symptoms, and see what they quote you for repair; if it costs more than half the price of a new motor ( ~$140-150? ), then I wouldnt bother- you can get a Castleneu 1515 for $140 from Mike (kv rating choice is limited but there should be something suitable for you available)...
EDIT: 1515 3d = 1360kv, thats kinda low- maybe the 1512 1800kv motor would be good, if geared down, then it would have about the same torque & speed at the wheels; there are also various 1512 neu motors on sale on the neu website:
http://www.neumotors.com/store/page10/page10.html
