Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
AAAGH! I wasn't expecting that Mike!
pinkpanda3310
pinkpanda3310's Avatar
AAAGH! I wasn't expecting that Mike! - 02.24.2010, 08:59 AM
It arrived today! Yes it arrived only just today (not the slipper but the cd mount). I bought the cd mount asap and then went with standard snail mail. I know it's only a few more dollars for express international but I forgot
So I mock it up at work after picking it up from the post office and drool on it a bit then tonight I decide to mock up a motor and diff. Hell, why not, lets fit the slipperential!
AAAGH! It doesn't fit! I wasn't expecting that. Did I not read or miss something? I know the 50+ tooth spurs don't fit with out a little dremelling but I honestly thought Mike's slipper will fit Mike's cd mount.
You can see the bearing stops short of the housing
jokerjustin
RC-Monster Cheap Ass
jokerjustin's Avatar
02.24.2010, 09:17 AM
that is very strange..
02.24.2010, 11:36 AM
Hardly strange. The slipperential is small so it can fit the majority of setups with shimming. The cd mount is large to fit with standard diffs.
Mike clearly states that the mount requires some mods fir mist setups and us nit for novices. Just drill another hole in top plate or add shims to both bearings.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
02.24.2010, 11:45 AM
Drill another hole in top plate to move upright back for the bearing to get in the hole.
02.24.2010, 11:50 AM
Judging by the distance the bearing has to go, looks like he will have to drill a new top plate hole AND do some shimming on both sides.
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
02.24.2010, 11:51 AM
Mike clearly states that the mount requires some mods for most setups and is not for novices. Just drill another hole in top plate or add shims to both bearings.
Exactly. Smaller diffs like the Slipperential need shimming. I may modify the front mount on the next batch for easier use(I have an idea to make fitting various diff sizes much easier), but the product as it is was meant to be "universal fit" - it doesn't fit any diff specifically, but should allow most every diff with proper shimming. I would suggest shiming both sides of the diff - about 1.5-2mm per side should center it up nicely. If you drill a new top plate hole, the mounting template would be null and void. :)
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
02.24.2010, 01:55 PM
Perhaps Mr. Monster Mike would consider selling a top plate specifically to fit the Slipperential?
02.24.2010, 02:12 PM
But like Mike said, the actual mount holes in the chassis would need to be re-drilled as well...
If anything, maybe he could make a bearing spacer...
What's_nitro?
02.24.2010, 02:17 PM
I was thinking from the perspective of a completely custom installation. If someone was making their own chassis and such.
pinkpanda3310
02.24.2010, 07:14 PM
I don't mean it to sound like a whine. I just automatically thought the universal slipdiff would be a direct fit to the universal cd mount.
I do have the nouse to make this work. I was just a little surprised and thought other members might like to know
RC-Monster Mike
Site Owner
02.24.2010, 08:00 PM
I considered matching the mount to the Slipperential, but didn't want to alienate all those larger diff users out there. The Slipperential is "universal" because its small size allows it to fit where most other similar units(diffs) are installed. The 3 piece motor mount is "universal" in exactly the opposite manner - it is large enough to accomodate the larger variants of the center diff.
Finnster
KillaHurtz
Finnster's Avatar
02.24.2010, 08:03 PM
Why not make a top plate with an additional mounting hole ~4-5mm back?
Not much meat left to drill a hole to much further back in the original.
The drill template can then have a couple different drill holes depending on the mounting style.
1st gen stuff always has some growing pains, but I lookig forward to the next batch.
What's_nitro?
02.24.2010, 08:07 PM
It just occurred to me that it wouldn't be too difficult to make a new top plate myself.
RC-Monster Mike
Site Owner
02.24.2010, 08:10 PM
4-5mm would probably be too far back for many diffs - there is less than 4mm difference between most diffs and a 3.3mm hole that is 4mm offset from another 3.3mm hole is practically a slot. :)
RC-Monster Mike
Site Owner
02.24.2010, 08:14 PM
The easiest way to modify would be to simply shorten the legs on the existing top plate - I made the legs long enough and drilled and tapped the holes deep enough to allow this as an option. If you remove a known amount and move the mount holes for the front the same amount on the template, you have a smaller package that fits smaller diffs directly. :)
