Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
bdebde
That's All Folks!
bdebde's Avatar
03.05.2010, 09:39 PM
The losi Battery tray fits the Muggy quite well, I only had to drill one hole.
riverat1540
riverat1540's Avatar
03.06.2010, 04:14 AM
i ordered one from mike but i ordered the 45x168 with the shelf for the esc but for some dumb reason i was thinking my turnigy 5000's would fit in there but the tray was way to narrow. so i finally sent it back to mike and am ready for the right sized tray, so as soon as he gets it and i get my credit ill get the right one and all will be good, still thinking about those shock towers, it changes the stance so much!
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
V0RT3X
Muggy love
V0RT3X's Avatar
03.06.2010, 07:49 AM
What tray did you use before? I will probably use the Losi tray on mine, I like it in my 8ight-T.
This should fit with the label upwards:
http://www.hobbycity.com/hobbyking/s..._40C_Lipo_Pack
riverat1540
03.06.2010, 11:31 AM
It was an old custom zippy tray from mike that i purchased from another member, but when i sold my CRT i included it. mike makes great trays and I try to support him when i can.
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
V0RT3X
Muggy love
V0RT3X's Avatar
03.07.2010, 01:55 PM
Can you measure the ride height? (from the lowest point) Wonder if this will be able to replace my Savage Flux for crazy bashing.
riverat1540
03.07.2010, 04:19 PM
its at 2.5in with the muggy shocks in the position it is in in the pics
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
Mozzy
Mozzy's Avatar
03.08.2010, 05:41 AM
I was reading about your muggy's weights & decided to weigh my LST.
It came in at 12lb 5oz = 5.58kgs ready to run with a 5S 4000mAh.
Not bad considering my X1CRT tipped the scales at 5kgs = 11.02lbs ready to run with the same pack.
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
riverat1540
03.08.2010, 11:04 AM
It definitely has some weight to it but i carries it well. its amazing what those big tires absorb!
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
V0RT3X
Muggy love
V0RT3X's Avatar
03.30.2010, 12:50 PM
Is the center diff the same as the 8ight's?
bdebde
That's All Folks!
bdebde's Avatar
03.30.2010, 03:12 PM
Yes, the diff itself is, but the mount is different.
JThiessen
JThiessen's Avatar
04.04.2010, 02:29 PM
There's about a 1/4" difference in height of the mounts. I was going to try to use my RCM 8T mount in my Muggy, but it wouldn't line up correctly with the other stock muggy mount. The bearing size on the muggy is larger than the 8T mount also.
V0RT3X
Muggy love
V0RT3X's Avatar
05.24.2010, 02:37 PM
Got my roller, some questions:
Should I run a plastic spur? What's the largest one that will fit without spacers on the RCM mount? What pinions will fit?
How do I get rid of the stering slop?
Will LST towers give me more clearance?
Can InnovativeRC make me a bit wider chassis on one side? (it will be tight to fit the 6500 Hyperions flat since they're 70mm wide) Anyone got an email? Can't get a response from him.
1717 or 1520? (have a 1520 in my Savage now)
bdebde
That's All Folks!
bdebde's Avatar
05.24.2010, 03:19 PM
Plastic spur will work, 46t is max on stock chassis, 48t if you go innovative chassis, but I would recommend a steel spur for durability on heavy rig.
New steering parts get rid of most slop, also use a turnbuckle in the center instead of the factory link.
LST towers will only help with LST shocks AFAIK.
I can find Innovative's e-mail when I get home.
The 1520 should be plenty (running one in mine), and the 1717 may limit gearing options (big pinions required).
riverat1540
05.24.2010, 05:01 PM
+1 could not have said it better myself.
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
V0RT3X
Muggy love
V0RT3X's Avatar
05.25.2010, 03:12 PM
Managed to get the address?
