Thomas Porfert
Thomas Porfert's Avatar
03.08.2010, 04:54 PM
Can any of the Castle guys give an update on when they expect the Field Links to be sent out to people who used the coupon that was included with the Mamba Max Pro?
If you chose to upgrade to the field programmer for $10.00, we should be shipping those out shortly. If you can PM me your info, I can look it up and give you an update. If you only asked for the standard free link, we are currently working on some and they should be available soon as well.
Thomas Porfert
Castle Tech Support
Frost
03.08.2010, 11:10 PM
Here are the answers to your questions:
What controller are you trying to program?
- Mamba Monster Max (F310C)
What version of software is on the controller?
- V1.24 (Beta)
What version of software do you have on the computer?
- Castle Link version 3.251
Have you ever connected the Field Programmer to the computer?
- Yes. No problems encountered when using Castle Link software to set the MMM ESC via Field Link. The problem only happens when using Field Link powered by battery via MMM ESC.
Joe Ford
Castle's Chaos Corner
Joe Ford's Avatar
03.08.2010, 11:19 PM
Thanks for the quick reply Frost. We'll test this out tomorrow!
Joe Ford
Product Specialist
J57ltr
03.08.2010, 11:24 PM
I had a weird thing happen when changing to a cutoff of 9V. Everything programmed fine, but when I went to use the truck the next day the motor just shuttered in both forward and reverse(like it was set for brushed).
The wires battery and motor got very hot in just a few seconds. I got the programmer out and checked the settings and when I went down to motor type it was set to brushed reverse. I changed it back to brushless and everything was fine. I was pretty sure it was user error.
Jeff
Frost
03.09.2010, 02:27 AM
For your reference, I have uploaded a video showing the Field Link in operation. Initial Field Link setting for Motor Type set to Brushed Reversing. I do a continuous press to change parameter value to Brushless, and then a single-click to go to next parameter, the value changes to Brushed Reversing instead, and then skips Motor Timing setting.
[YOUTUBE]<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/sq-wt0cNeb0&hl=en_US&fs=1&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/sq-wt0cNeb0&hl=en_US&fs=1&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>[/YOUTUBE]
gixxer
gixxer's Avatar
03.09.2010, 07:02 AM
Thomas Porfert
Castle Tech Support
Thats great, I will have to due that when my next mmp gets here.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
Thomas Porfert
03.09.2010, 05:46 PM
Frost,
I just had another go at it again and was able to recreate the problem. The only thing I can suggest is to slow down. I think the Programmer is missing the click, so try waiting just a second after changing the setting, then click it again to go to the next setting. When I slowed down I couldn't recreate the problem, but when I did it quickly like you did in the video, it recreated the problem every time.
Thomas Porfert
Castle Tech Support
Last edited by Thomas Porfert; 03.09.2010 at 06:11 PM. Reason: Misspelled Frost's name, there's no Y at the end :P
glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.09.2010, 06:36 PM
There you have it.... this device is not intended for use by gamers or meth addicts. It's more a tweeker kinda thing LOL
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
Frost
03.09.2010, 09:05 PM
Thomas: Thank you for the advice. Somehow it doesn't happen to the other parameters on Field Link, but only the Motor Type and Motor Timing parameters. Nevertheless, it is a great product, and I like it very much. I find it very useful at the racing track
gixxer
gixxer's Avatar
03.11.2010, 12:32 AM
just ordered mine tonight with the code from my esc. look forward to trying it out.
simplechamp
simplechamp's Avatar
03.22.2010, 05:20 PM
I just received my Field Link today from the $10 coupon offer.
Also, thanks to Thomas for the great customer service!
