how to check if diff are still LSD or not ?
Jason
how to check if diff are still LSD or not ? - 04.09.2010, 10:40 PM
I have doing a small mods to my stampede to put it LSD few months ago and now want to recheck if it is still LSD anyone know how ?
04.09.2010, 11:18 PM
OK This ones got me LSD?
skellyo
skellyo's Avatar
04.09.2010, 11:24 PM
I was guessing limited-slip diff? Otherwise, his Stampede needs to visit rehab.
Jason
04.11.2010, 05:32 PM
yes limited slip diff
simplechamp
simplechamp's Avatar
04.11.2010, 08:00 PM
What mod did you do exactly and/or what about the mod makes it only temporary?
bryan
bryan's Avatar
04.11.2010, 08:49 PM
WOW DUDE
nitrostarter
nitrostarter's Avatar
04.11.2010, 09:52 PM
Unless you glue the differential spider gears together, you will always have a "LSD"
To check for it, pick up the truck and spin the wheels...
N. Rustler conversion
Andrew32
04.12.2010, 10:40 AM
arnt the mag transmissions open diff out of the box? you would have to seal and add oil or putty or peanut butter or jelly or ky
MikeW
MikeW's Avatar
04.12.2010, 12:11 PM
I use Ky for optimum performance out on the track
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
04.12.2010, 12:42 PM
It's perfect for the tight corners !
nitrostarter
04.12.2010, 12:45 PM
Helps the holeshot as well.
MikeW
MikeW's Avatar
04.12.2010, 12:48 PM
Also gives you maximum control in the pit lane which can be a very tight fit.
04.14.2010, 12:42 AM
this thread oozes "WIN"
Andrew32
04.14.2010, 12:47 AM
sounds life all you need for a PERFECT day the "tracks"
Jason
04.19.2010, 11:49 PM
ok.. let me explains some more
when I lift the truck in the air and turn one wheel by hand the other wheel dont move look like it need more pressure..
when I lift the truck in the air again and turn the spur by hand the both wheel turn in the same way..
when I lift the truck in the air and push some gas throttle the both wheel turn the same way even at low speed..
so my diff are LSD right ?
