Semi Pro
Semi Pro's Avatar
05.03.2010, 04:07 PM
I use stick on wheel weights for full size cars. Just trim them down to 1/16 oz pieces. After I get them balanced I cover the sides in hot glue. Have not had one come off yet!
thats not a bad idea
how often do you rebalance them?
i redo mine when there is about 50-60% left
05.03.2010, 05:51 PM
I check them but they stay in reasonable balance, at least for my tastes. I did a test by balancing the wheels on one side and leaving the other side unbalanced. At 45mph the unbalanced side was coming off the ground, it was vibrating that bad. No wonder I am so good at controlling these things, I ran at least 2yrs without balancing!!! One wrap of lightweight duct tape on the tire also does wonders for ballooning.
jpoprock
"Don't act like you're not impressed."
jpoprock's Avatar
05.18.2010, 01:55 PM
I've dyed the bright yellow Proline's orange before. If you use Scarlett (red) dye and let them soak for literally 2-3 min tops, they come out orange. I've also used Sunset Orange Dye too, and let them soak for a really long time, and they are as orange as the ones I soaked in red for a couple minutes.
However, the downside with anything dyed, is that if the rims get scratched at all, you can almost always see the orig color because the dye doesn't fully penetrate the rim.
Also.. if you use Royal Blue dye over the yellow rims... and let them soak for 2-3 minutes, they'll turn a really cool color of green. But soak them too long and they will start to turn blue. I've dyed many yellow rims primary colors like Red, Blue, Orange, Green, and even Black, just as easy as i have white rims.
ERBE: RCM 1/8 Hybrid Diffs, NEU 1515/2.5d/S MMM, 6S, Losi E-XXL CUSTOM, Neu1515 2.5d, MMM, 6s E-SLAYVO PRO ERevo Chassis w/ Pro 3.3 parts, NEU 1512, MMM, 4S.
  Send a message via Yahoo to jpoprock Send a message via AIM to jpoprock
bent70
09.27.2010, 02:28 PM
What motormount are you using? I ordered a 1717 and was going to go with mikes mount, but read about fit issues with the big can.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
09.27.2010, 03:23 PM
Order the heli version, it has flat sides and should allow much easier installation.
Semi Pro
Semi Pro's Avatar
10.03.2010, 06:07 AM
its the rc monster motor mount
the smallest gearing i could get to mesh nicely was 18/44
you can gear lower if you space the diff up alittle and go with a larger spur, with spacers you can run as low as 17/50
i really like the 1717 in the muggy............the muggy diffs are takeing quite a beating, between the heavy beadlocks and my driveing it alot hard i keep brakeing the pins.
my diffs are currently set up 7k/30k/3k
bent70
10.03.2010, 01:26 PM
Ok cool i ordered mikes mount and should have all my stuff by monday. My muggy is pretty much all stock except for a 50t spur. Im debating running the stock tires or throughing on some 17mm adapters and running maxx sized tires and rims i also have.
