05.17.2010, 02:24 AM
Originally Posted by Chadworkz View Post
If the LiPo and Device positives are connected to the same pad, the LiPo will directly power the Device without passing through the Protection circuitry.
Not if the grounds are seperate, which they are. Normally, you see circuit interruption in the + lead, but there is nothing wrong with switching the ground lead. In fact, that's how old-style dome lights are switched on via pin switches in older cars. Car horns operate in a similar way. Just depends on the application. Could just be a matter of the circuit using an NPN vs a PNP transistor to do the switch action...
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.17.2010, 02:31 AM
Okay, do you see the labeling though Brian? If you ignore the drawing they provide, doesn't it look like they are switching the + batt terminal?
rawfuls
roofles.
rawfuls's Avatar
05.17.2010, 03:39 PM
Got a quick email back...
"Hi Justin,
Thank you for your e-mail. The circuit diagram that you provided does
look correct.
Best regards,
Don Clark
Batteryjunction.com
-----Original Message-----
Sent: Monday, May 17, 2010 12:16 AM
To: CustomerService
Subject: Contact Request Form
My Question
Comment: ************Hi, your labels on the Protection Circuit Module
(PCB) for a single cell Li-ION:
http://www.batteryjunction.com/prcimopcbfor.html
Is quite confusing.
I'm not sure which the P , B *and such are actually going to, so would
like to make sure.
If I wire up a battery, to connect to this module, which will then wire
out to a connector, would this diagram be correct? Thanks!
05.17.2010, 03:45 PM
That photobucket pic is missing. It would be nice to know what the proper wiring was...
zero: The labeling is a bit "crappy", but the pic I posted makes sense assuming I am reading their label correctly.
No matter what, if I were to buy that device, I would be reverse-engineering it to make sure I knew what goes where. Those ICs are most likely commonplace for those types of modules, so a datasheet lookup should tell the tale.
rawfuls
roofles.
rawfuls's Avatar
05.17.2010, 03:52 PM
I think it's around post 29
05.17.2010, 03:56 PM
Ok cool, that's just like the diagram I posted except I put the battery on top and the load/charger (connector in post 29's diagram) on the bottom. Same connections though...
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
05.17.2010, 05:06 PM
here is the fixed picture he posted above...
-Chad
PM ME IF YOU HAVE THE BELOW:
rawfuls
roofles.
rawfuls's Avatar
05.17.2010, 05:35 PM
Thanks Chad:
I'll be waiting for the "MintyBoost" to see if I can even solder it up, and get it working before I order a LiPo and the board...
