xcelorin systems any good? -
05.18.2010, 06:28 PM
Anybody have any experience with the xcelorin 1/8 scale brushless systems? Just wondering if they're worth it or should I just stick with the MMM system. My next project is a LST2 conversion & trying to see the pros & cons of both systems.
05.18.2010, 07:10 PM
From what I gather, the esc is crap, but the motor is quite good. On balance, I'd say stick with the MMM
Fat Kid Engineering
05.18.2010, 07:20 PM
Losi ESC's are Junk, The motors are better but still have doubt.
Go with Castle or Tekin Systems, they can both be found here in the RCM store.
05.18.2010, 07:24 PM
Losi...NO
Castle or Tekin...YES
enough said
05.18.2010, 07:39 PM
they are great............................................. .........................................in the micro-t................................................. ..........everything else...nope
Originally Posted by Semi Pro
Originally Posted by BrianG
05.18.2010, 10:04 PM
+1
both castle and tekin also have awesome customer service just in case something goes wrong.
05.18.2010, 11:45 PM
ESCs are a piece of crap. I have the losi xcelorin 2100kv motor and mamba monster esc on my 8ight conversion. It runs extremely smooth, cool and quiet.
05.19.2010, 06:17 AM
+1 more for NO!!!!!
get a castle combo
Hyper 10sc mmm 2650
Ae rival mmm 2200
Ae rival 1717....work in progress
Losi micro sct/rally
2 KiloWatt RACER
05.19.2010, 10:04 AM
I use to run the Losi ESC. Worked great untill I updated the firmware and the majic smoke came out.
For ESC's stick w/Tekin/Castle.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
05.19.2010, 10:28 AM
In Europe the losi motor has the reputation to toast
The ESC last meanly ~ 10 runs ^^^
The customer service often result in a "Your fault, you inverted polarities"
Just go for a Castle ;)
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
05.19.2010, 11:42 AM
Thanks for all your replies, so that settles it then stay away from Xcelorin. Now to decide, MMM or Tekin RX8....decisions, decisions.
05.19.2010, 12:52 PM
Bashing=MMM
racing=tekin
atleast that's the way I usually see it done--Josh
05.19.2010, 03:12 PM
Okay I'm going with MMM but I do want to use the new 1518 1Y motor, I think it would be better for the LST 2 than the 2200kv one, any thoughts?
Fat Kid Engineering
05.19.2010, 04:17 PM
The 2200 is a fine motor for the truck on 4s, I ran mine on 4s for well over a year and no heat problems and it would yank the front wheels off the ground in a heartbeat.
If you want to run 5s or 6s then the 1518 or 1520 would be the wiser choices.
Smokless Nitro
05.19.2010, 04:29 PM
We have a lot of electric 1/8th scale running around in my area. Given that I own two Mamba Monster 2200kv combos and three Tekin combos w/four motors: 1350kv, 1700kv, 2050kv, 2250kv, I have come to the following conclusion:
Mamba Monster = Monster Trucks
Tekin = Buggy and Truggy
Everyone will have their own opinion on this, but from my own experience, go with Tekin when you need solid control. The CC Monster is too abrupt and is more for a wow factor or where tiny input is not noticed, hence, monster trucks. I had the Monster combo in by converted XT8 and it was horrible. My previous experience with it was on my ERevo which was a blast. I had to dial it WAYYY down on the XT8 and even then, it sounded like it was destroying the drive train. I switched to the Tekin 2250kv Truggy combo and BAM, it was beautiful. Everything was so much smoother just at default settings and my drive train was safe again.
Some quick tips:
When using Tekin, go with the correct format: buggy motor for buggy and truggy for truggy. I used a truggy on a buggy and it wasn't as smooth as the buggy motor.
When using Castle, do not buy the 2650kv ever unless you are running 3S on a buggy.
Sensored matters!! Make sure you get a sensored setup unless its a bashing monster truck.
Just my take...
Linear Mode
