Thread Tools Rating: Thread Rating: 16 votes, 4.75 average. Display Modes
bryan
bryan's Avatar
06.11.2010, 03:29 PM
Originally Posted by JAILBIRD View Post
. I did make one mistake though, I must have entered something in the speed calc wrong and ended up ordering the wrong pinion. A 25t with a 2250kv T8 might be a bit much.
-JB
Ya think
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
06.11.2010, 10:49 PM
Whoa, 25T pinion, hehe!
Anyway, be sure to post lots of pics of your conversion/build progress when you get the truck and get started!
-Chad
PM ME IF YOU HAVE THE BELOW:
nitrostarter
nitrostarter's Avatar
06.14.2010, 10:55 AM
Can someone get a measurement on shock lengths from the Ten-T, both from and rear shocks, at the mounting point? greatly appreciated...
N. Rustler conversion
bryan
bryan's Avatar
06.14.2010, 03:23 PM
Front 3 1/4", Rear 3 3/4" center to center.
Why is there smoke coming from your ears
I thought about a set of 2.0 shocks but they are a little off ,but would possibly work with a little modification.
nitrostarter
06.14.2010, 03:32 PM
Slash 4x4 upgrade...
XXXDAD
XXXDAD's Avatar
06.18.2010, 03:25 PM
If its not a Losi I dont drive it !Go losi Ten E Buggy!
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
XXXDAD
XXXDAD's Avatar
06.21.2010, 04:02 PM
Picked up a Roler for $200 so the Conversion is on... Where are the picks of SCT's from this Project ?
So the MC2 wheel adapter kit is a better option if I want closer to SCT withs?
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
shenri
06.22.2010, 01:29 AM
You mean these:) I asked Casey on the losi forums how he managed the wheelbase. He said he flipped the rear arms left to right and did a little dremel work, got 23mm longer out of it, but you loose the droop screws.
He also said that the best way in the future will be a proper chassis.
XXXDAD
XXXDAD's Avatar
Thumbs up 06.22.2010, 09:22 AM
What bumpers are those and what did you do to your truck... I need info good info so I dont go the wrong way! Help a brother out! Thanks for posting pics... is this the RC Monster conversuin kit?
Put some words down.... Make of parts and where you got them and price is nice too!
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
bryan
bryan's Avatar
06.22.2010, 07:30 PM
He used an 8ight conversion. Mikes RCM conversion is much nicer and durable,and cooler looking!!!!!!!
XXXDAD
XXXDAD's Avatar
06.22.2010, 07:33 PM
I'm down to use Mikes set-up! Now what bumpers are those?
Did you see the new Tekin 550 long can SCT motors comming out in 4.5 & 5.5... thats what I can run and be in the class rules! Sweet!!
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
bryan
bryan's Avatar
06.22.2010, 11:37 PM
You may want to have your LHS put that motor on order if you want one before next year.either one should work great depending your gearing-battery.
FG101C
06.23.2010, 01:59 AM
I would also like to know what bumpers those are. They look like Traxxas, but looking at amain's website I don't see them under Slash, Slash 4x4 or Slayer.
I flipped my arms, but instead of mounting the shocks they way he did it, I mounted them to the front side of the tower and stock position on the arms. The wheel base is now there, thinking either ProTrac wheels or m2c 17mm hex adapters.
Also the Slash 4x4 front bumper pretty much mounts right up.
What would be cool would be if you could post the link to that build from the Losi forum, because I can't find it on there anywhere.
XXXDAD
XXXDAD's Avatar
Lightbulb 06.23.2010, 11:48 PM
Nice job on the back end... shocks look like they are perfect. Now... can the droop screw be re drilled and taped? More guys more! Mine is here in 5 days...
think im going with 18t pinion to work with the R1 448 motor combo i already have. Then its the new Tekin SCT motor for me when they come out. M2C 17mm wheel adaptors and some prolines....
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
Moller123456 !
06.24.2010, 07:20 AM
http://www.youtube.com/user/mollis123456 More video's of the ten-t :)
  Send a message via MSN to Moller123456 !
