ANGRY-ALIEN
ANGRY-ALIEN's Avatar
06.07.2010, 09:59 PM
Originally Posted by 95ROLR View Post
I've been running the 1520 in my LST XXL for a few weeks now on 6s. Geared for 45mph, I ran 2 packs through it yesterday back to back and at the end of the second battery, my motor temp was 117 degrees. Temp was 24 degrees (Celsius) up here in Canada. The truck can handle the power very nice, however my diff output cups are starting to notch out where the dogbones hit. I'm thinking about picking up some of Mike's Hardened diff cups (I think I saw some?).
I love this motor. It makes me smile. I couldn't imagine this motor in a Savage though, what a waste
Wow.... 117°... could you post your setup and some photos of your machine?
95ROLR
06.07.2010, 10:03 PM
Yeah, I was baffled. I had a 2200 in there previously and knew that the lower KV geared would be more efficient/cooler, however I was afraid because I geared for a higher mph with the 1520... that the motor temps would be up in the high 150's (I understand that 175 is pretty much max?).
I will post setup/pics tomorrow. I'm just in the middle of cleaning the truck up from a good day yesterday :)
Jahay
06.08.2010, 04:15 AM
castle told me that the motor was good as long as you kept it below 200!!! but i will stick to max 180!
@scarlett.... i have used the HD gears 2 times now and both sets have stripped on me in around 12 runs or so! Its cheaper to use stock ones and change them every 6-10 runs and they have better contact surface area. Just works out better for me till i do the CD conversion.
@rolr... get some pics up of this xxl lst... Im sure my savage would love to run all over it your geared for 45 im geared for 53mph lol jk.
But seriously what is your lst weighing in at? just want to compare how these trucks weigh compared to their gearing etc... and what temps they are producing.
nuz69
nuz69's Avatar
06.25.2010, 04:31 AM
http://www.vimeo.com/12832488
The motor is in the purp MBX5T truggy ;) You can see some air at the end, and how easy the motor works to push it in 3-4meters altough the high punch control at 70% !
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
ANGRY-ALIEN
06.25.2010, 10:46 AM
Look... It's a Bird...It's a Plane... it's SuperMBX5T... damn that thing can fly... nice vid man... keep them coming...
Alien
snellemin
2 KiloWatt RACER
snellemin's Avatar
06.25.2010, 11:02 AM
Nice vid man.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
95ROLR
06.27.2010, 09:31 PM
Sorry for the late response. Here are some pictures of my bashing beast.
-LST2
-XXL Chassis conversion
-MMM/1520 motor
-Flextek Titanium arms
-Aluminum hubs
-Tini Pinion/Spur/diff gears/tranny gear
-Forward only conversion, E-LST gear swap
-I made a make-shift battery tray out of an old parts container while my new one was being shipped, however I continue to use it as it does the trick quite well.
I absolutely love the weight setup of the truck... As much weight forward as possible, and it still jumps level!
Don't mind the crappy pictures or state of the truck, just waiting on some parts to beef up the corners a bit more.
Jahay
06.28.2010, 04:48 AM
i love those arms!!! look so good! YOUR LST IS HAUGGEEE
V0RT3X
Muggy love
V0RT3X's Avatar
06.28.2010, 08:04 AM
117°C is 242°F. Castle motors must be kept below 200°F or 93°C.
My motor stays cool in my Savage on 6S with 20/44. Still flips too easy though. Need to swap all the stuff to the Muggy now, the center diff should be great for handling.
Pdelcast
Pdelcast's Avatar
06.28.2010, 10:20 AM
He was stating that it was 117°F, not C. Read the post carefully.
Patrick del Castillo
President, Principle Engineer
V0RT3X
Muggy love
V0RT3X's Avatar
06.28.2010, 10:23 AM
Yeah, figured it later since the other guys would think it's still really cold in Canada. (or is it?)
nuz69
nuz69's Avatar
06.30.2010, 04:11 PM
Check the mugen spur and the rear shaft ;) Shimming was always correct
ANGRY-ALIEN
06.30.2010, 04:27 PM
Interesting... what make pinion are you using? I don't normally see that kind of deterioration on spurs...
Alien
nuz69
nuz69's Avatar
06.30.2010, 04:30 PM
Many ^^
RCmonster pinions : eated after 5-10 bateries :(
Robinson racing : eated...
losi : eated..
ect..
ect..
novak : seems to be no digestive for the moment
Thomas Porfert
Thomas Porfert's Avatar
06.30.2010, 04:34 PM
I feel silly for asking, but that's not the gear mesh you normally run, right?
