Go Back   RC-Monster Forums > Support Forums > Unlimited Engineering
changing from nitro to brushless.
emaxxthemonster
jt racer
changing from nitro to brushless. - 07.13.2010, 11:23 PM
i have a full blown ue supermaxx. it has a vbs set,racerx,spider 6s,6mm axles, ue shocks,strobe limiters etc... i have a jt racing chassis for it. i am looking to put one of mikes center diffs with the brushless motor mount.
can anyone tell me which one will fit?
can i take off the top plate and just put traxxas 7075 turnbuckles or pushrods running from the center diff to the vbs top mount i have seen it done with other trucks.
also i am looking for a set of sun 7s rims if any one can lmk where i can find a set of those or if you have a set you can sell me or trade me.
here are some pics of the truck right now.
here is some of my extra parts i have. i am keeping the other racer x kit for a future build with the thunder chassis. i am also keeping a set of towers.
emaxxthemonster
jt racer
07.13.2010, 11:26 PM
emaxxthemonster
jt racer
emaxxthemonster
jt racer
07.13.2010, 11:27 PM
emaxxthemonster
jt racer
07.13.2010, 11:28 PM
i am new with photobucket and i was not sure what to do until i say the image code.
so here are the pics. can anyone help me out.
emaxxthemonster
jt racer
07.13.2010, 11:29 PM
i am also looking for setbacks it doesnt matter if they are new or not.
i also have an extra set of ue diffs i can trade also.
emaxxthemonster
jt racer
07.14.2010, 01:21 AM
if anyone has RACERX SETBACKS,VBS FT RR JOUNCES, VBS FT RR BUMPERS, SUPERMAXX STICKER SHEET i will give them my UE DIFFS. they are dirty and need a good cleaning.
emaxxthemonster
jt racer
07.14.2010, 01:28 AM
i almost forgot
i am going to be running a tekin rx8 2050kv motor. 2 3s lipos. i wanna do about 40 45 mph. can anyonw help me out on the gearing
07.16.2010, 03:19 AM
The biggest spur you can fit with Mike's mount is a 48 (without modification).
I wouldn't go with any smaller pinion than 12t (there just isn't good mesh w/ smaller pinions).
With the 2050/kv motor on 6s with bowtie tires(typical truck racing tire) and 12/48 gearing you would be geared for 67mph. Way too fast.
There are two problems I see:
1. The 2050/kv tekin motor is a buggy motor. For a maxx you want a truggy motor, and specifically for your setup, one with a lower kv.
2. UE super diffs. "UE" diffs are just relabeled ofna buggy diffs. This lower buggy ratio was meant for use with a center diff and buggy size tires. With a maxx transmission there is enough gear reduction to use "UE" buggy diffs, but when you switch to a center diff "UE" diffs are geared a little high.
The solution:
Get the 1700/kv tekin TRUGGY motor. On 6s with bowties and 12/48 gearing you will be geared for 47mph.
emaxxthemonster
jt racer
07.16.2010, 10:15 PM
hey, thanks alot paralyzed.
i was reading some other threads and another member said that there was a chart for gearing.
could you tell me where i can find it or maybe give me a link to it.
for the center diff is the - ofna habao st pro spider diff - good for what set up i am using.
07.17.2010, 12:27 AM
hear is the gearing app: http://www.scriptasylum.com/rc_speed/index.html
It is found in the first sticky in the brushless section.
It was all written by BrianG, a moderator here. Just start clickinmg around in it. It's all drop down menus and super easy to use, and very very helpful.
That ofna spider diff should work great. I'd start with 10,000wt oil in it and adjust from there.
plettenbergs
plettenbergs's Avatar
07.17.2010, 12:42 AM
check this out...UE THUNDER WITH RCM center diff!!
uses two thunder rear cvd's for centers!!
emaxxthemonster
jt racer
07.17.2010, 03:08 AM
thanks again to paralyzed
you are right it is very easy to use. i could figure out the gearing i wanted to use in a minute.
plettenbergs
sweet truck. i am probrably going to use that on my thunder chassis in my next build. also another thing sweeeetttt knuckles.
does anyone know where i can get a set of supermaxx sun 7's rims.
