MMM 2200KV sounding like a Electric Drill ??
sabongi
MMM 2200KV sounding like a Electric Drill ?? - 08.16.2010, 02:45 PM
Just got my MMM, took it out of the box, installed EC5 plugs and ran it.
Motor is making a electric drill sound, something like a really bad bearing or something.
What can i do?
I'm in Brazil, so it would take 1 month to send it back, and probably 2 months to receive it back from you.
Can't afford waiting all this time. Is there something i can do?
Bearing oil maybe?
nvtuning
08.16.2010, 03:15 PM
if your rotor isn't damaged and you are willing to drive again soon buy a new bearing others you wil need to contact tech support
greets nvt
rc8te/NEU 2200kv/mamba monster/4cells lipo
savage/castle 2200kv/mamba max pro/4cells lipo
scx-10/castle 4600kv/mamba max/2cells lipo
bruce750i
bruce750i's Avatar
08.16.2010, 03:26 PM
Both are/have electric motors and may sound alike.
Did you run the 2200 installed in a Rc or just holding it in your hand?
Does your electric drill run okay or does it get hot and smoke?
You can take the 2200 apart pretty easy to take a look around inside. Take the front end bell off and install a pinion(for grip and to hold bushing on shaft) then slowly and strongly pull the rotor out. Note the number of bushing on the shaft on both sides of magnets. It should have some clay on the end of the rotor where it was balancing.
DCastaneda
Speed Addict
DCastaneda's Avatar
08.16.2010, 03:43 PM
I have a CC 1512 1.5Y that has a distinct "click" over one spot in the rotation of the rotor. Took it apart bearings fine rotor looks ok to me. Any ideas?
Durango DESC410r MMM CC/Neu 1410
B4.1 Worlds MMP RevTech 17.5
SC10 MMP RevTech 17.5
XRAY T2R MMP Duo3 10.5
SC8E MMM CC/Neu 1520 6s
Inferno GT HV- W.I.P. 12s CC HV110
  Send a message via AIM to DCastaneda
sabongi
08.16.2010, 04:20 PM
It was in my hand!
Runs ok, no heat or smoke!
Took it apart, only one bushing on the front and another on the back. Bearings look ok.
Anything else?
Maybe too much axial play?
Maybe the brass bushing size is wrong?
bryan
bryan's Avatar
08.16.2010, 08:09 PM
Are you reffering to the noise that a cordless drill w/a clutch sounds like?
93firebird
08.16.2010, 09:14 PM
I thought you weren't supposed to run them with out having them installed in a vehicle!!
Freezebyte
08.16.2010, 09:46 PM
Uh dude, I hate to tell you this but you NEVER want to run a brushless motor without any kind of a load on it. I think you just blew the bearings
sabongi
08.16.2010, 09:56 PM
i never got to full throttle, just below middle...
bryan
bryan's Avatar
08.16.2010, 09:57 PM
Actually running the motor with no pinion at WOT is required for the new motor/kv test.
Personally
I think he blew a diff.
sabongi
08.16.2010, 10:00 PM
The motor was in my hand... out of the car...
bryan
bryan's Avatar
08.16.2010, 10:20 PM
Please attatch pix of what you are doing.These motors are very "notchy" with no power applied.Or FREEZE may be right and you did f up a bearing?
Freezebyte
08.16.2010, 11:13 PM
Noo............... try again
http://www.rctech.net/forum/electric...motor-get.html
http://e-savage.com/forums/showthread.php?t=4527
http://www.rcgroups.com/forums/showthread.php?t=119101
jholthus
08.16.2010, 11:18 PM
In the castle link software when you do the KV motor test it tells you to either pull the motor away from the spur so there is no load on the motor or just take the pinion off the motor.
bryan
bryan's Avatar
08.16.2010, 11:26 PM
Sorry FREEZE.but those links have nothing to to do with the motor k/v test that are now offered through the castle link
