Thread Tools Rating: Thread Rating: 16 votes, 5.00 average. Display Modes
brian015
brian015's Avatar
08.17.2010, 08:21 AM
Originally Posted by thzero View Post
Tad light? How so? I'm running a CC2200 right now...
1512 or 1521?
thzero
08.17.2010, 08:28 AM
Yup... same thing that is on the XL just that I de-anodized the spacers.
Originally Posted by Bmr4life View Post
Are those the HPI 86249 wide axles?
thzero
08.17.2010, 08:51 AM
1512 1.5Y. The important part is bolded. It is a 1800kv motor. The 1512 1Y is the 2650kv motor. Although its Amp rating on the 1512 1.5Y may be a bit low I suppose even though it has the same max. voltage as the 1515/1518/1520.
http://www.castlecreations.com/produ...le_motors.html
Originally Posted by brian015 View Post
1512 or 1521?
brian015
brian015's Avatar
08.17.2010, 10:09 AM
Then, yes, its too small - smaller than your CC2200 - its made for buggies whether its 1y or 1.5y.
Nard Cox
n00b
08.17.2010, 10:50 AM
I'm with brian on this one. The 1512 is a buggy motor, the 1515 is MT/truggy a 1521 is for monsters like your ride ;). Oh well, I'm not expert but it just sounded a bit strange to me.
08.17.2010, 11:25 AM
I'm going for a 1717 on 6s in mine - :)
brian015
brian015's Avatar
08.17.2010, 04:37 PM
What you're interested in is the power they can handle. If you look at Neu's specs:
1500 motor specs
you can see that the:
1512 is rated to 2000 Watts
1515 is rated to 2500 Watts
1521 is rated to 3500 Watts
etc.
It's not the kv that matters for choosing a motor for a specific size vehicle, it's the physical size of the motor and the power it can handle. Then you choose kv for the particular gearing/battery voltage/etc. of your setup.
08.18.2010, 07:50 AM
Indeed- any 1512 motor is designed for a buggy or light truggy, weighing maybe 6-8lbs, not exactly ideal for a 1/5 MT weighing closer to 15-20lbs- I'd use a minimum of a 1515, more like the 1518 or 1520 if you were going with castleneus..
thzero
08.18.2010, 08:35 AM
Well I am using a 1515 right now. :P But yes I will probably drop to a 1518 or 1520 depending what will fit length wise.
brian015
brian015's Avatar
08.18.2010, 10:03 AM
What is your point here? You were saying that a 1512 was a good alternative to the 1515. And a number of us were trying to explain why it wasn't. So this is where you say, "thanks guys for setting me straight and helping me not make a stupid motor choice."
thzero
08.18.2010, 10:21 AM
Thanks guys for setting me straight and helping me not make a stupid motor choice! :)
Although I thought it was obvious by saying that yes I probably would move to a 1518 or 1520!
brian015
brian015's Avatar
08.18.2010, 10:44 AM
Nard Cox
n00b
08.18.2010, 01:31 PM
Good choice
thzero
09.27.2010, 12:00 PM
Was on the front page of BigSquid.
mac3194
RC JUNKIE!!!!
mac3194's Avatar
10.10.2010, 03:29 PM
can u please explain to me how you mounted the body because im making a custom 5b conversion.
thanks
