Bmr4life
09.28.2010, 03:00 PM
Got my first "rough draft" mount done while at work today. I definitely learned a lot while making it. It works for the stock gear set, but has almost no movement since I botched the drilling of the mounting holes on the bottom. If I ever want to run a different pinion, like a 25t, I'll have to slot the motor mount bolts so I can get more side to side adjust ability.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
09.28.2010, 03:15 PM
Originally Posted by mini_t racer View Post
you have a great project mate but what is the red part fitted to the spur gear if i may ask
Looks like a home made spring washer (rubber o-ring)????
http://204.186.93.64/SlipperSpring.htm
Don't know why but mine has a plastic race rather than metal like in the picture ?
mac3194
RC JUNKIE!!!!
mac3194's Avatar
09.28.2010, 03:21 PM
It's a part from kershaw designs it comes in the spring washer kit. I'm not exactly sure what the red piece is called though.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
09.28.2010, 03:30 PM
"Thrust Bearing"
mac3194
RC JUNKIE!!!!
mac3194's Avatar
09.28.2010, 06:10 PM
thanks lol
Gdot
10.01.2010, 03:06 PM
this is a beast
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.01.2010, 03:14 PM
Should have complete build pics later today/tonight
Just finishing the little stuff today, had to jump through hoops to get a top control arm to work w/the HPI aluminum axle carriers and FLM bulks, everything was to long or to short.
So I had to make my own, PITA !
Bmr4life
10.01.2010, 04:07 PM
Can't wait!!
Nard Cox
n00b
10.01.2010, 06:21 PM
Finally a reason to get out of bed tomorrow morning
88gtanotchback
10.01.2010, 08:05 PM
lol im looking forward to it as well...maybe not as desperate as these guys tho.
_dV
10.01.2010, 09:19 PM
It will be interesting to see what kind of benefits\drawbacks eventuate from running a motor of this size in a Savage truck.
Nard Cox
n00b
10.02.2010, 05:07 AM
I got out of bed for nothing ?
Finnster
KillaHurtz
Finnster's Avatar
10.02.2010, 09:51 AM
lol
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.03.2010, 03:53 PM
Finially finished the entire assembly, Had insomnia last night and was balanceing tires at 4am. I haven't ben feeling the greatest the last couple days so I may not test until Monday or Tuesday ?
I installed the ESC(pulled red wire) , 1200mah 2s ThunderPower RX battery and RX on battery tray, lots of room for electronics there.
Mounted and balanced PL Trenchers on 23mm 40series 1/2" offset Dyed PL Velocitys
The XL body doesn't fit to bad, Think the next thing I may consider makeing will be a roll cage for the cab and tie into the F&R shock towers ? A roll over w/this Heavy assed MoFo will destroy some Polycarbonate.
Time to look for some 1/4" 7075 solid rod and fire up my aluminum welder.
Bmr4life
10.03.2010, 05:30 PM
I like those wheels and tires. How much do they weigh?
