Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Real 17mm hexes
LiqrSicc
LiqrSicc's Avatar
Real 17mm hexes - 09.29.2010, 04:37 PM
Is there a solution for this yet? Man, I can't stand these locknuts. I've already rounded 2 of them. I'm not a big fan of Integy but I might have to give these a try if I have no other choice:
http://www.integy.com/st_prod.html?p...46&p_catid=202
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
  Send a message via AIM to LiqrSicc
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
09.29.2010, 05:07 PM
Go up to 23mm hubs ?
LiqrSicc
LiqrSicc's Avatar
09.29.2010, 09:25 PM
Yeah but that means I have to go 40 series. In that case I might as well go 24mm and slap some 5b's on there. I was hoping to keep this build light too.
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
_dV
09.30.2010, 07:05 AM
I've seen it mentioned that
HPI-38305: Wheel Axle 8x11x47mm (from Savage 5T)
http://www.hpieurope.com/piw.php?lang=en&partNo=38305
could be used in a savage so that 'normal' 17mm mounts like the ones on the Vorza could be used. I haven't seen reports from anyone who has actually tried it though.
I don't have much trouble with the stock Flux nuts but the proper 17mm nuts would be easier to work with i think. Anyone know if there are other off the shelf solutions other than the Integy one? The Integy ones look to come in a variety of offsets too which could be handy.
Interesting.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Interesting. - 09.30.2010, 07:22 AM
Actually those do look interesting. These look pretty cool as well.
http://www.integy.com/st_prod.html?p...09&p_catid=108
I think I may have to make a purchase from Integy as well.
SUPERMAXX YOUR LIFE.
_dV
09.30.2010, 07:45 AM
Hmmm, something to note. None of those hex hubs are list in the Flux section http://www.integy.com/st_main.html?p_catid=267
JThiessen
JThiessen's Avatar
09.30.2010, 09:56 AM
So what exactly is the issue with the stock 17mm's? Is it just the nut on the outside? If that is it, I would have agreed with you right after I got my Flux, but after running it for a couple years, it is the only truck I have had that I have NOT lost a wheel. Hence, I live with the small nuts...
LiqrSicc
LiqrSicc's Avatar
09.30.2010, 10:16 AM
I guess it's just the annoyance. I swap wheels and tires all the time so a 17mm hex would be a lot more convenient. I did find some random Kyosho hexes in my parts and it fit the axle perfectly with no play at all. I just need a barrel nut to secure it to the axle itself. Anywas I'm going to do some research on the 5T axles, if not I might just test out the Integy's.
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
09.30.2010, 10:24 AM
There are still 23mm maxx sized rims availible ?
http://cgi.ebay.com/Pro-Line-Velocit...item2307940f43
Finnster
KillaHurtz
Finnster's Avatar
09.30.2010, 10:38 AM
Those 5T axles are interesting. Too bad they aren't avail in US, and they are horribly expensive from Europe.
Bazzokajoe
09.30.2010, 01:12 PM
those 5t axles are just truggy axles... any 1/8 buggy or truggy uses them... i just converted my Mad force to them... work wonderfully :)
hyper 7 ones are dirt cheap too... and more than strong enough for crazy bashing :)
Finnster
KillaHurtz
Finnster's Avatar
09.30.2010, 02:08 PM
I'm talking about the axles, not the hexes. That's why the axles are nice, then you can use the more universal 'uggy hexes.
They have offset hexes too to gain more width if needed.
There are a number of cheap integy hexes on ebay. They have upto 9mm offset, but there is one set that goes upto 12mm offset, but is not on Integy's ebay store. There used to be a number of hexes for the hypers that had large offsets too, but I can't seem to find them anymore.
Finnster
KillaHurtz
Finnster's Avatar
09.30.2010, 03:23 PM
*** I was referring to the integy uggy hex hubs earlier.
IDK about the Savage ones. The only concern I would have would be what they are using as a sleeve for the axle threads, esp for such a large offset. I had ofna hex adapters for the revo way back when and the steel threads ate into the soft alu of the hub and eventually caused wobbling. I eventually made my own sleeve for the threads from 7075 tubing, but never tested it long term to see if would hold up better.
LiqrSicc
LiqrSicc's Avatar
09.30.2010, 09:10 PM
Found the thread:
http://www.savage-central.com/module...wtopic&t=86983
Just waiting to get a response from somebody. I don't mind spending the money on them as long as they work.
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
LiqrSicc
LiqrSicc's Avatar
10.01.2010, 03:07 AM
So I guess those 5t axles do fit but they need to be shimmed behind the pin. Not so sure if I like the idea of that. I guess these are the only 2 choices:
http://www.integy.com/st_prod.html?p...007&p_catid=59
or
http://www.integy.com/st_prod.html?p...44&p_catid=202
Are these Flux axles the same size as the 4x4 Slash axles? The AKA 17mm adapters would work out perfectly if the threaded part of the axle were the same size.
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
